Page 12 of 18
Re: OctaneRender® for ArchiCAD 2.24.2 [TEST]
Posted: Tue Oct 13, 2015 3:46 am
by face_off
can we generate grass scatter files from within the Revit plugin?
No, that's not something that's possible in the Revit plugin. It was added to the AC plugin as an experimental feature - to see if it provided a viable option for rendering grass. I'm not sure that anyone has used it though (as I haven't seen any renders with the plugin generated grass) - so I can only assume that it's not been a particularly useful feature.
Posted: Tue Oct 13, 2015 8:50 pm
by BfPuVAK
I have refreshed the installer at the top of this thread with:
2.24.2.55...
Yip, it works again
Many thanks,
Artur
Duplicate material
Posted: Thu Oct 29, 2015 11:23 am
by s3d-weyrauch
- 151029_Duplicate_material.jpg (34.59 KiB) Viewed 6487 times
Hi Paul,
I get this message on every start of a Project. I didn´t see other Problems depending on that. But please could you describe it, why I get something like this?
Thanks a lot
Posted: Thu Oct 29, 2015 9:54 pm
by face_off
Hi Paul,
Thanks a lot
Can you pls update to the latest test build and let me know if the problem still occurs there?
Posted: Mon Nov 23, 2015 8:47 am
by face_off
2.24.2.57
- Fixed issue where the LiveDb was not available after loading large ArchiCAD scenes
2.24.2.56
- Change to allow reading of Surface name from ArchiCAD with more than 31 characters. Only works with AC19.
Posted: Sat Dec 19, 2015 9:35 pm
by face_off
Following is a pre-release of the Octane3 version of the ArchiCAD plugin, for ArchiCAD 19 only at this stage.
3.0.0.58
- Compiled with Octane 3.0.0
- Added Medium and Medium Radius to the Daylight and Texture Environment settings
- Added new Render Passes
- Removed "Ambient" and "Sample Environment" GI Modes from the Direct Light kernel
- Added Deep Image settings to the kernel settings
- Added support for VDB files (add them in proxy ORBX files)
* If your default rendertarget has Render Passes->Info After Beauty ticked, I suggest unticking it and re-saving your default rendertarget
* KNOWN ISSUE: if you pause rendering, change an Octane setting, then continue rendering, the Viewport will freeze (and you will need to refresh the scene to restart the Viewport).
You can install and use this version with your Octane 2 license.
As this is the first Octane 3 build of the ArchiCAD plugin, exercise caution and keep backup of the 2.24.2 versions of your scenes.
https://render.otoy.com/customerdownloa ... _64bit.exe
Posted: Mon Dec 21, 2015 11:47 am
by kxl
Hi Paul, thanks for the update!
I was wondering if the plugin will suport texture baking?
Cheers
Stefan
Posted: Mon Dec 21, 2015 9:21 pm
by face_off
It should do, when Baking is added to the Octane API alpha.
Re: OctaneRender® for ArchiCAD 3.0.1 [TEST]
Posted: Mon Dec 28, 2015 11:38 am
by face_off
3.0.1.59
- Compiled with Octane 3.0 alpha 2 (3.0.1)
- Added new Octane 3 Infochannel Types
- Added Baking Camera. This does not appear to be working - and I suspect this is due to the UV coordinates that ArchiCAD supplies being absolute, and not rpeating in a 0-1 range.
- Manual updated with Octane 3 features. Pls see
https://docs.otoy.com/ArchiCAD/?page_id=443 for details.
3.0.0.58
As this is the first Octane 3 build of the ArchiCADplugin, pls make backups of your scenes prior to using the plugin.
Posted: Mon Dec 28, 2015 11:42 am
by rappet
Thanx a lot Paul!
