Page 11 of 20
Re: Version 3.06-TEST-2 (WORK IN PROGRESS BUILDS)
Posted: Sun Mar 05, 2017 11:54 am
by aoktar
thanulee wrote:Its not actually. Ur attitude and ur tone is annoying, while I politely asked 3 times about this. U been ignoring me and thats unacceptable. If u do not understand that part of ur job description is to reply/explain to each customer (even if u consider him/her an annoying prick) and not selectively as well as equally respond to each request, then something is terribly wrong here.
For the actual request:
U designed it to work this way, its not a standalone feature, its a simple c4d option and i guess (actually i do not guess i asked other devs how hard is something like this) that it would be very easy to implement it. But u choose not to. Have a nice weekend.
Let's make it clear. I don't have any problem with users or people. But i don't have to answer every questions or there's no any rules to answer or see every questions. You cannot expect a special personal attention for yourself. There's lot of people and i cannot answer everybody by stealing time from development or support. This is a forum and its purpose that's getting help from others or helping to others.
For next;
I'm developing this plugin alone also having support responsibility. And shaping up at same way. Nobody is aware of hardness of this. Working on 7/24 sometimes and trying to cover up the missing features of core or C4D sdk's weakness for what i want to do. If somethings is possible or it's time to start then i do. Otherwise i'll not. There's priorities, roadmap with issues and impossibilities.
Posted: Sun Mar 05, 2017 3:30 pm
by bartolos
You are clearly under a lot of pressure.
I know what you feel. It says more about your employer than you Ahmet.
You're a wizard, and wizards make magic happen, but customer support is a completely different thing.
Posted: Mon Mar 06, 2017 1:40 pm
by KonstantinosD
Hello,
Small suggestion for nodes editor if I may, (see attached pic)
Problem: If I want to select multiple nodes, I can drag the mouse and form a square that selects everything inside, however if I want to select only the nodes in the circles to copy them in a new material I can't at the moment without selecting the others as well. (of course if I'm wrong here please let me know how and read no further )
Suggested solution: Hold down ctrl or shift or anything and add nodes to selection or remove them, if something like this can be added to the plugin.
Regards,
Konstantinos
3.06-TEST-2 MacOS Node Editor not appearing
Posted: Mon Mar 06, 2017 4:56 pm
by rwalker
Using 3.06-TEST2 on Mac OS 10.11.6, C4D 16.050, GTX 780+GTX780ti, nVidia Web Driver 346.03.15f02, CUDA Driver 8.0.63 - when I create an Octane shader and click on "Node Editor," the Node Editor does not appear. Nothing happens. What do you think?
Posted: Mon Mar 06, 2017 6:05 pm
by aoktar
KonstantinosD wrote:Hello,
Regards,
Konstantinos
I'll add shift for additive selection. Btw at the moment copy/paste from material to material is a possible option. Or opening the two materials in NE and duplicating by ctrl+drag is another one. So ctrl is reserved for duplicating. Just an info for you.
Posted: Mon Mar 06, 2017 6:14 pm
by KonstantinosD
You rock!
Konstantinos
Re: 3.06-TEST-2 MacOS Node Editor not appearing
Posted: Mon Mar 06, 2017 7:47 pm
by rwalker
rwalker wrote:Using 3.06-TEST2 on Mac OS 10.11.6, C4D 16.050, GTX 780+GTX780ti, nVidia Web Driver 346.03.15f02, CUDA Driver 8.0.63 - when I create an Octane shader and click on "Node Editor," the Node Editor does not appear. Nothing happens. What do you think?
Reverting to 3.03.3-R1 restored "Node Editor" function. Any ideas why it would not be working in 3.06-TEST2?
Posted: Mon Mar 06, 2017 7:48 pm
by eyeonestudio
<<< Render failure detected!!! >>>
3.06 T2 (caching system test version)
With Environment Fog
Posted: Mon Mar 06, 2017 8:06 pm
by lucioing
bartolos wrote:You are clearly under a lot of pressure.
Dear friend,
maybe you don't realize how much we, c4d user, are lucky to have Ahmet as developer. If you don't, please, BELIEVE me...
I think that, in THIS post, we have to help Ahmet in finding critical step, operations and so on.
The suppor is ONLY for the stable release, I mean...
Anyway, every note, advice and so on, are welcome if that mean to reach the stable release as quickly is possible.
Thank you again, Ahmet, for you heavy job.
L.
Posted: Mon Mar 06, 2017 8:19 pm
by rwalker
rwalker wrote:rwalker wrote:Using 3.06-TEST2 on Mac OS 10.11.6, C4D 16.050, GTX 780+GTX780ti, nVidia Web Driver 346.03.15f02, CUDA Driver 8.0.63 - when I create an Octane shader and click on "Node Editor," the Node Editor does not appear. Nothing happens. What do you think?
FIXED. Re-installed 3.06-TEST 2 standalone and c4doctane plugin, all working OK now.
