Page 2 of 3
Re: OctaneRender 2024.1 Alpha 3 for Houdini production
Posted: Tue Mar 26, 2024 1:30 pm
by chocbot
ricky_otoy wrote:Thanks for the report, I am currently looking into this. It seems this may be a core issue as I don't think it is intended to bounce light from other sources.
Alright, thanks for the info!
Posted: Tue Mar 26, 2024 5:44 pm
by lavrenovlad
Hey Ricky,
I don't use standalone octane so cannot tell, one thing is for sure in 2023 denoiser always worked perfectly and this issue appeared in 2024!
Posted: Wed Mar 27, 2024 7:31 am
by ricky_otoy
lavrenovlad wrote:Hey Ricky,
Hi, under Octane plugin Options > GPU's (Change Tonemap to the other GPU to see, also try swich which does the denoising)
Posted: Fri Mar 29, 2024 4:18 am
by lavrenovlad
Yep, just did some of the tweaking here and there switching this stuff around, the AI denoiser is absolutely cooked, it stably crashes no matter what I try. Pure garbage stability in 2024, never had issues with Octane denoisers before until now
Posted: Fri Mar 29, 2024 4:22 am
by lavrenovlad
I should try standalone at this point
Posted: Wed Apr 03, 2024 3:44 am
by lavrenovlad
AI denoiser doesn't seem to work properly too. I have a scene right now with very bright spots + glare turned on in post-process. On one of the frames one of the flares goes overly bright and basically covers the whole IPR after denoiser is applied, but without it, it looks fine.
Posted: Wed Apr 03, 2024 7:17 am
by ricky_otoy
lavrenovlad wrote:AI denoiser doesn't seem to work properly too. I have a scene right now with very bright spots + glare turned on in post-process. On one of the frames one of the flares goes overly bright and basically covers the whole IPR after denoiser is applied, but without it, it looks fine.
I will have a look, but generally it is easier if you supply us with a scene of the problem. Things like that may generally be a core issue imo.
Posted: Thu Apr 04, 2024 1:40 am
by lavrenovlad
I saw somebody complaining about the denoisers too in other channels, so I guess most of these are core issues introduced in 2024. I'll try to export a scene for that to take a look
Posted: Thu Apr 04, 2024 1:44 am
by lavrenovlad
BTW can those crashes and stuff be also related to Windows 10 updates? This year windows updates were terrible, most of them not installing properly and for the first time I experienced BSOD when rendering in IPR (only with octane though). I installed windows updates 2-3 times this year after which I couldn't boot up properly, had to recover and try again, even now I have one security update that just won't install, such bullshit
Posted: Thu Apr 04, 2024 7:44 am
by ricky_otoy
lavrenovlad wrote:BTW can those crashes and stuff be also related to Windows 10 updates? This year windows updates were terrible, most of them not installing properly and for the first time I experienced BSOD when rendering in IPR (only with octane though). I installed windows updates 2-3 times this year after which I couldn't boot up properly, had to recover and try again, even now I have one security update that just won't install, such bullshit
It is possible, issues with corrupt OS files can also produce BSOD. But I can't be 100% sure... Please also try export the ORBX and have a look at how standalone behaves with the denoiser.
You could try the following for windows to scan the OS file system:
sfc /scannow
and another for the windows update:
DISM.exe /Online /Cleanup-image /Restorehealth
**You shouldn't need to, but in case I would just backup important files. This is just more of a disclaimer :D
