Page 2 of 2
Re: TexSelector : a multi texture using material ID
Posted: Wed May 03, 2023 9:34 pm
by neonZorglub
HHbomb wrote:Hi, NZ.
This is not working for exemple when using a mixmaterial. No object are detected.
Hi HHbomb,
Ho, right, sorry about this ! I must be checking only 1 level of material .. This will be fixed in the next release!
A temporary work-around, for testing the TexSelector, is to first apply a Diffuse material with a dummy TexSelector as Diffuse texture to your objects. Then, you see those objects in the dummy TexSelector and can setup them with the 'Fix issues' button.
Once it's done, the objects will keep those settings (the Octane Geometry modifier), and can be used with a Mix Material / sub material / TexSelector..
Thanks for reporting this issue.
Posted: Wed May 03, 2023 9:36 pm
by neonZorglub
samsue wrote:It is some material, but I can't find it.
After I apply a diffuse material to the whole scene, it starts immediately.
Hi samsue,
Thank you for the clarification.
I will check more the render start time with your scene..
