Page 2 of 3
Re: next problem trying to load or export to from orbx
Posted: Sun May 23, 2021 12:10 pm
by face_off
Sorry for the late reply.
Traceback (most recent call last):
File "C:\Program Files\Poser Software\Poser 12\Runtime\Python\addons\OctaneRender\SetupForm.py", line 2248, in MenuSelectionCb
File "C:\Program Files\Poser Software\Poser 12\Runtime\Python\addons\OctaneRender\MaterialManager.py", line 2367, in MenuCommand_LoadMaterialFromORBX
ctypes.ArgumentError: argument 1: <class 'TypeError'>: wrong type
This is a python2-to-python3 issue, which I will fix tomorrow and post a new release.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Poser.exe
Application Version: 12.0.500.0
Application Timestamp: 608b0778
Fault Module Name: octane.dll
Fault Module Version: 10.2.15.0
Fault Module Timestamp: 606fa760
Exception Code: c0000005
Exception Offset: 0000000000641cd7
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 3081
Additional Information 1: 5706
Additional Information 2: 5706c96869159c094ec5c421d1fd601c
Additional Information 3: f282
Additional Information 4: f282cbe07c044b99da7fe5d4a428ceb1
I have not had a crash from Poser 12 caused by Octane yet, so I am guessing the crash is either due to some geometry in your scene, or Out-Of-Core issues, or the displacement amount being too high for a material in the scene. Can you please confirm that the crash only happens when you are rendering with Octane (ie. it doesn't happen if the Viewport is closed)? And can you try turning OFF Out-Of-Core memory. Also check and remove any displacement maps from material to see if that helps.
Posted: Sun May 23, 2021 1:22 pm
by maldowns
Problem signature:
Locale ID: 3081
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Posted: Sun May 23, 2021 1:33 pm
by maldowns
It seems to be random but yes when opening the viewport, I can re boot poser load the scene hold my breath and it will render
I have managed four renders tonight in this scene each one different camera angles different size different poses etc each time one or two crashes then it will render properly
I will try your suggestions cheers
Posted: Mon May 24, 2021 5:34 am
by face_off
maldowns wrote:It seems to be random but yes when opening the viewport, I can re boot poser load the scene hold my breath and it will render
If you bundle up a scene which is crashing more often than not, send it to me and I will take a look.
Posted: Mon May 24, 2021 6:58 am
by maldowns
I'm not sure how to do that and maybe you don't want my adult graphic novel scenes either lol
i am wondering if it is to do with the python thing it seems to crash more checking and accessing the textures etc mainly when I go to open the view port but sometimes when i first open the plug in but it is odd its sort of random, I keep working as is for now until your update you spoke of doing is ready, I am in the habit of saving the scene every time I make an adjustment so i don't lose everything on a crash
Posted: Tue May 25, 2021 1:46 am
by face_off
I have posted an EXPERIMENTAL Octane 2021.1 release at
viewtopic.php?f=45&t=77770&p=400967 which you should try to see if it resolves your crash. Make sure to keep a copy of the Octane 2020 version of your scenes before saving with the Octane 2021 version of the plugin, in case you need to revert back to the Octane 2020 version of the plugin.
Also, remember to try my suggestion of disabling Out-Of-Core.
Posted: Tue May 25, 2021 8:02 am
by maldowns
Thank you man that seems to fix my initial problem on orbx but the next thing on the crashes i am wondering if it is something to do with mouse sensitivity and my dodgy right hand with rsi creeping in it seems to happen more when i am trying to select something like opening the view port
Posted: Tue May 25, 2021 8:19 am
by face_off
maldowns wrote:Thank you man that seems to fix my initial problem on orbx but the next thing on the crashes i am wondering if it is something to do with mouse sensitivity and my dodgy right hand with rsi creeping in it seems to happen more when i am trying to select something like opening the view port
I've had no other reports of these types of crashes. Have you tried turning off Out-Of-Core?
Posted: Wed May 26, 2021 12:13 pm
by maldowns
yep out of core is off only other variable i can see is i have had an external hard drive plugged in to my tower that keeps wanting to autoplay which i did not have plugged in before upgrades
Posted: Thu May 27, 2021 4:36 am
by Zay
maldowns wrote:yep out of core is off only other variable i can see is i have had an external hard drive plugged in to my tower that keeps wanting to autoplay which i did not have plugged in before upgrades
I have the same problem with Standalone. Octane won't start for a very long time when USB devices are connected. I had to move everything I need for 3D on internal SSD's to prevent the long loading time of the app and have the other USB devices turned off when using Octane.
