Page 2 of 4
Re: OctaneRender® for 3ds max® v2020.2.1 - 11.07, 3dsMax2022
Posted: Mon Mar 29, 2021 4:30 pm
by HHbomb
@ Paride : Yes, my fault (again)
But it seems that I'm in a very bad mood these times... I misunderstood that I can revert to old behavior, I thought at a toogle...
Posted: Mon Mar 29, 2021 4:33 pm
by HHbomb
@anifex3D : It seems that there is a hang because the installer is scanning hd for installed max versions.
Posted: Mon Mar 29, 2021 9:16 pm
by neonZorglub
HHbomb wrote:Hi,
Added support for tyFlow particle Age. If you have a file to share I'll be happy. I can't manage to make it works.
Hi HHBomb,
I added a sample to the tyFlow post :
viewtopic.php?f=27&t=73516#p398609
Posted: Tue Mar 30, 2021 7:13 am
by mbetke
I get this connection error since a few versions now. Even with scenes containing one surface only. Render stops with GPU error. Using the latest studio drives.
What's up there?
OctaneRender Enterprise 2020.2.1 (10021301)
Can't connect node 'oDiff_07 - Default' (NT_MAT_DIFFUSE, 00000234577DBBD0) to static pin 'layer' (P_LAYER, type PT_MATERIAL_LAYER) of node 'Universal material' (NT_MAT_UNIVERSAL, 0000023415C6A8B0)
Posted: Tue Mar 30, 2021 10:15 am
by samsue
max closes without warning while trying to save images directly from Octane Viepower. ( 2000x 11GB vRam scene )
Posted: Tue Mar 30, 2021 11:15 am
by mbetke
CUDA Error on a very small scene. Happens from time to time. Whole driver crashes and I need to restart 3dsmax.
Failed to create CUDA context
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 1: unspecified launch failure
-> failed to download symbol(stats data)
device 0: path tracing kernel failed
device 1: path tracing kernel failed
CUDA_ERROR_LAUNCH_FAILED: unspecified launch failure
denoiserThread0 : Exited with a error. Restart required
denoiserThread1 : Initialization failed. Restart required
-> failed to destroy CUDA event
Posted: Wed Mar 31, 2021 1:16 am
by neonZorglub
mbetke wrote:CUDA Error on a very small scene. Happens from time to time. Whole driver crashes and I need to restart 3dsmax.
Hi mbetke,
Could you provide this small scene ?
Posted: Wed Mar 31, 2021 6:53 am
by mbetke
I've sent you a PM with the link.
Posted: Wed Mar 31, 2021 10:58 am
by mbetke
Used Universal Camera the first time and got a bunch of error while playing with the settings.
Even a GPU Error and ender stop.
Started logging on 31.03.21 08:28:08
Empty file name.
Empty file name.
Can't connect node 'tx-Map #10' (NT_TRANSFORM_2D, 000002A41C0453F0) to static pin 'bump' (P_BUMP, type PT_TEXTURE) of node 'mtl-Leika2' (NT_MAT_UNIVERSAL, 000002A42E957580)
Empty file name.
Empty file name.
<nodes>:26: error: No matching function call to 'evaluateTileGrid (color, string, float, float, int, int, int)'
Candidates are:
void evaluateTileGrid (color, string[], float, float, int, int, int)
We generated invalid OSL code
Candidates are:
Failed to compile OSL shader.
Candidates are:
Candidates are:
Empty file name.
Empty file name.
Posted: Wed Mar 31, 2021 12:03 pm
by samsue
Imager White Balance dont affect he Octane View ( using normal cam from max) I have already reported this many times.
