Page 2 of 19
Re: UNOFFICIAL plugin for 3ds Max 2010+
Posted: Wed Aug 03, 2011 3:39 pm
by JimStar
I think I found the reason. Fixed it in 1.15.:)
Posted: Wed Aug 03, 2011 3:55 pm
by Jaberwocky
JimStar wrote:I think I found the reason. Fixed it in 1.15.:)
coool ... i'll give it a try. ;)
Posted: Wed Aug 03, 2011 4:07 pm
by Jaberwocky
Jim
Yes It works perfectly now.
I uninstalled 1.14 and reset max back to default settings.Reset the max start Ui and rebooted max.
I then reloaded V1.15 and it installed perfectly including the 2 commands in the bottom of the render menu.
if no one else reports any problems you could probably ditch the 2 or 3 diagram screens on the front end of the plug in installer.
Cheers
Jabba
Posted: Wed Aug 03, 2011 4:18 pm
by JimStar
Found small bug in plugin itself... Fixed in 1.16...
Posted: Wed Aug 03, 2011 4:58 pm
by Jaberwocky
Not sure if I'm doing something wrong but pressing the render animation button does not start rendering an animation.
Posted: Wed Aug 03, 2011 5:06 pm
by Jaberwocky
Tried re-running one of the stock max 2012 animation scenes and this then came up.It might be a clue
Posted: Wed Aug 03, 2011 5:08 pm
by JimStar
Jaberwocky wrote:Not sure if I'm doing something wrong but pressing the render animation button does not start rendering an animation.
Does export process begin after pressing? Or nothing happens?
If export begins - can you check please what is in the "Renders/Animation" folder after pressing?
Posted: Wed Aug 03, 2011 5:14 pm
by JimStar
I found some bug in animation processing, fixed it in 1.18. Maybe it will resolve issues...:)
Posted: Wed Aug 03, 2011 5:15 pm
by Jaberwocky
The animation folder is empty.See the attached the project folder one level up.
Edit ----- OK will try V1.18------------
Posted: Wed Aug 03, 2011 5:19 pm
by Jaberwocky
Ok
V1.18 seems to have fixed it.It's now rendering the animation in the background whilst i type this.
I'll report back when its finished.
Cheers
Jabba
