Page 2 of 3
Re: OctaneRender 2020.1 LightWave Beta build 2020.1.0.2
Posted: Sun Jan 26, 2020 5:25 pm
by Lewis
hkleton wrote:Hi,
No positive result with only the non-displaycards active.
Keep in mind, with NVIDIA driver 431 LW/Octane 2020 DOES render, only when switching to the newest driver 441 and thus really enabling RTX it fails.
Only using the 1080ti's and disabling RTX also does not result in a succesfull render.
Yeah as i said i suspect Out Of Core is crashing with RTX (did you tried with RTX off?) or not using it properly, I've seen scenes where with OOC slowsdown to 3-4x slower in 2020.x (or v 2019.1.5) than v4.05 with same OOC usage.
Posted: Sun Jan 26, 2020 11:28 pm
by dbajurin
Anybody have an isue when rendering from lightwave image with Z depth render pass using also enterprise slave. In this combination slave crash. I can render raw pass, postprocessing pass but I can't render Z depth. I have this isue also with 2019 version.
Posted: Mon Jan 27, 2020 1:38 pm
by dbajurin
One error while rendering reflection of spectron area light
OctaneRender 2020 LightWave Manual update?
Posted: Fri Jan 31, 2020 5:25 pm
by PaGz
Hello Juan, Do you know if the Octane render manual for Lightwave 3d will be updated to version 2020?
The last publication already dates from 2017 :(
Version 3.06.4.0 - Manual publication date: 26 May, 2017
Best regards :)
Posted: Fri Jan 31, 2020 5:31 pm
by juanjgon
Yes, there is a technical writer working on it, so it will be updated at some point this year.
Posted: Fri Jan 31, 2020 6:03 pm
by PaGz
Great news :)
Thanks Juanjo!
Posted: Tue Feb 04, 2020 4:00 pm
by Carlos3D
Why when I'm rendering with the native Limite region on, does Denoiser not work?
Posted: Tue Feb 04, 2020 4:02 pm
by Carlos3D
Carlos3D wrote:Why when I'm rendering with the native Limite region on, does Denoiser not work?
Posted: Wed Feb 05, 2020 3:21 am
by pixym
From what I know, V4 Denoiser did never work with limited region. I don't know if this limitation is still in use with 2020…
Posted: Wed Feb 05, 2020 7:16 am
by Carlos3D
pixym wrote:From what I know, V4 Denoiser did never work with limited region. I don't know if this limitation is still in use with 2020…
Unfortunately, I hope Juanjo looks at it with great affection because it is something very useful for us.
In still camera scenes I only need to render the first frame in Full resolution and the rest I would render in the region where there was some movement, many times it is a very small area that the octane would render in second.
There are also those moments when there is an irregularity in the rendering, a false color in the clothes, a reflection of the light in the mirror and I would only have to render in that region.
So I avoid being rendering the whole scene in full Res from the beginning.
