Page 2 of 4
Re: OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.15 RC5
Posted: Thu Sep 27, 2018 2:40 pm
by hkleton
Yes, same here, first render you do is black.
Render same frame again, and it is normal.
Posted: Thu Sep 27, 2018 4:39 pm
by BorderLine
Same here !
by pixym
I will send the scene asap. Octane aborts render after a few frames, about 40th. The abordting does not finish, so I have to End Lightwave then relaunch it.
Posted: Thu Sep 27, 2018 4:45 pm
by pixym
This is the attached packed scene, the log file is also included.
Posted: Fri Sep 28, 2018 9:51 am
by juanjgon
hkleton wrote:Yes, same here, first render you do is black.
Sorry for this issue. Somehow the Octane API function used to get the image data fails for the first rendered frame. We are investigating what could be the problem.
Posted: Fri Sep 28, 2018 10:06 am
by juanjgon
pixym wrote:This is the attached packed scene, the log file is also included.
Thanks for the scene. Yes, it seems some kind of issue with the denoiser, that fails reporting a message "denoiserThread0 : Initialization failed. Restart required". I'll try to report this issue to the core devs to see how it could be fixed.
Posted: Fri Sep 28, 2018 10:20 am
by juanjgon
You have the rendering mode configured to full scene reload. Can you please try to render the scene again in update mode to see if it helps?
Posted: Fri Sep 28, 2018 3:13 pm
by pixym
Hi Juanjo,
I will try that once I will be in my office and let you know if the issue still happens.
Posted: Fri Sep 28, 2018 5:05 pm
by pixym
Juanjo,
I have tried with both of these settings :
1 - Full scene reload = Render Failure at frame 42
2 - Update scene = No issue at all
Best.
Installation problem
Posted: Mon Oct 01, 2018 8:59 pm
by alperocak
Hi Juanjo.
I'm getting this error.
https://drive.google.com/open?id=1wQyo4 ... 8ux_3YNw5R
I'm using win7 64bit and LW 11.6.3 64 bit.
I'm trying to install from this folder.
https://drive.google.com/open?id=1quxE5 ... FLGPkojRlG
Thanks in advance.
