Page 2 of 2
Re: OctaneRender® for Maya® 3.08.3 - 12.53 [ STABLE ]
Posted: Wed Sep 12, 2018 3:32 pm
by Jolbertoquini
Hi Bikram,
I checked and I find a bug with OSL scripts I will paste the scene here, is working but each time when I save the scene and open again the OSL script are ignore after I just change a little option then start working as should, I think for some reason is not saving correct the OSL still on the scene but is not loading correct.
Please check this with JIM is quite a big issue cause we can render in batch and cmd, OSL scripts which is quite the all point to support OSL.
Cheers,
JO
Posted: Wed Sep 12, 2018 3:38 pm
by Jolbertoquini
Hi Bikram,
me again the "BRDF Model" is broked on the IPR I need to restart everytime when I need to change for lookdev is quite bad the fact we need to restart each time we need to change, And standalone doesn't require to stop the preview to change this options please a fix on the shader option would be great.
Cheers,
JO
Posted: Wed Sep 12, 2018 4:32 pm
by Jolbertoquini
Hi Bikram,
One other feature is complete broked is the OSL camera, wrong options for load is showing "images and IES" options basically using the script of light :shock: , and the edit is broked we can't add any OSL camera script.
The OSL texture node has the right look but with the bug as mentioned before please we need make sure Jim is checking this features.
Cheers
JO
Posted: Thu Sep 13, 2018 7:07 am
by coresign
why I can't render out Maya Mash, both geometry type and instance type.
Posted: Thu Sep 13, 2018 7:58 am
by BK
Hi jo, thank you so much for reporting these issues. We have created tickets on our bug tracking system.
Hi coresign, try applying Octane material before you create Mash instancers and make sure the geometry is not under a group node.. We are currently working on to support this ASAP!!
Cheers
Posted: Thu Sep 13, 2018 8:24 am
by coresign
BK wrote:Hi jo, thank you so much for reporting these issues. We have created tickets on our bug tracking system.
Cheers
Posted: Fri Sep 14, 2018 3:46 am
by Braca
Network rendering in batch render mode is not working in this version.
In the network preferences it is saying that slave is running, but the slaves GPU's are not used at all.
However in the IPR it works.
Posted: Fri Sep 14, 2018 4:08 am
by BK
Braca wrote:Network rendering in batch render mode is not working in this version.
Hi Braca,
Thank you!! any error message or a screenshot would be helpful.. we are not able to reproduce it.
What do you see in Daemon screen during the Batch render?
Could you please copy the `Octane_daemon_log_flags.txt` inside [ C:\Program Files\OTOY\OctaneRender 3.08.3 ] and PM us the logs?
Try install the MSI afterburner [ https://www.msi.com/page/afterburner ] to monitor the Slave daemon GPU stats.
Before saving the Maya file, Enable the "All available slaves for batch" from Octane render tab and "Use all available GPUs at full power" from the CUDA devices to maximize the Daemon's GPU usage.
net_render_slave_log_flags.zip
(527 Bytes) Downloaded 247 times
Cheers
Posted: Tue Sep 18, 2018 10:08 am
by Jolbertoquini
Hi Bikram,
News???on the updates...Please.
Cheers,
JO
Posted: Wed Sep 19, 2018 5:57 am
by BK
Jolbertoquini wrote:Hi Bikram,
Cheers,
JO
Hi Jo,
Yep, most of the reported bug has been fixed. Will try to release ASAP!!
Cheers
