Page 2 of 8
Re: OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.9 XB4
Posted: Tue Aug 07, 2018 10:02 am
by juanjgon
BorderLine wrote:Hi and thanks JuanJo,
There is a crash problem with network rendering ! First F9 render is OK but crashing in second F9 in the same scene.
Desactivate Network and it's OK !
Too bad because denoising with 6 Titan X, it's just perfect!
Franck
What crashes, LightWave or the render node? Be aware that some features like the AI lights are not supported yet by the network rendering. Can you enable the log file to see if there is any error message on it?
Posted: Tue Aug 07, 2018 10:28 am
by BorderLine
Lightwave crash !
Lightwave crash and after my 3 screens become black and i must reset my PC !
Log file attached !
Posted: Tue Aug 07, 2018 2:42 pm
by nico_cad
here works fine!!! thanks Juanjo!!! you are a great men with a big mind!!! :)
for use th last final plugin and standalone whats release need instal?
Posted: Tue Aug 07, 2018 3:19 pm
by BorderLine
nico_cad wrote:here works fine!!! thanks Juanjo!!! you are a great men with a big mind!!! :)
No problem with render network Nico ?
Posted: Tue Aug 07, 2018 7:32 pm
by DarkMoon
Nice! THNX!
Posted: Wed Aug 08, 2018 9:58 am
by BorderLine
BorderLine wrote:Lightwave crash !
Log file attached !
Hi JuanJo,
Any news for network rendering problem?
Posted: Wed Aug 08, 2018 10:06 am
by juanjgon
Log file attached !
Hi JuanJo,
Nope, sorry. Probably this is an Octane core issue. Do you know if the same happens if you try to render a scene using the Standalone, not the Layout?
Posted: Thu Aug 09, 2018 7:29 am
by promity
Is somebody have success with OSL node? None of the scripts that I downloaded from the forum are accepted by the OSL node in LW.
Posted: Fri Aug 10, 2018 11:50 am
by BorisGoreta
When rendering fibers in IPR Layout CPU usage goes to 95% as soon as IPR starts rendering, if I hit pause Layout CPU usage stays at 95% for 15 seconds and then it drops down to usual. MB is off. FiberFX IPR geometry update is off. My guess is that LW is regenerating fibers when it really shouldn't but that is just my guess.
It is correct that network rendering is not working on a second render, activate IPR->close IPR->activate IPR = LW crash, IPR actually continues to render fine.
Posted: Fri Aug 10, 2018 3:49 pm
by BorderLine
BorisGoreta wrote:When rendering fibers in IPR Layout CPU usage goes to 95% as soon as IPR starts rendering, if I hit pause Layout CPU usage stays at 95% for 15 seconds and then it drops down to usual. MB is off. FiberFX IPR geometry update is off. My guess is that LW is regenerating fibers when it really shouldn't but that is just my guess.
Yes Boris, same here !
