Page 2 of 2
Re: render layer system help please
Posted: Mon Nov 20, 2017 7:39 pm
by paride4331
Hi darkline,
I apologize for my delay but I had a lot of issues to check out.
I made this file and a video. I hope it helps to understand the workflow.
I do not think you can have an object that blocks light and simultaneously captures the shadow, so in your case you should take two steps.
Shadow catcher, which works essentially as a layer ID, needs to be disabled.
Posted: Tue Nov 21, 2017 10:55 am
by darkline
Hi Paride,
Thanks for taking a look. However, in the video I sent you none of the objects had a material with shadow catcher on them. I only used the render layer system. I did have objects with a camera mapped material so maybe that was the confusion, but I did not use shadow catcher. But I'll take a look at this file later and see if it helps, really appreciate it.
If, as you say this is something that cannot be done in a single step, is there somewhere i can post this as a feature request because I would think most people using octane for VFX work will want to composite shots onto existing footage and be able to have shadows fall across objects in the scene.
Posted: Tue Nov 21, 2017 5:41 pm
by HHbomb
Hi darkline
I give it a try, but it is not a direct render, composited in AE...
