Page 2 of 6
Re: Octane Render for SketchUp 3.07.0.14 Test Release
Posted: Tue Oct 31, 2017 1:29 pm
by -rb-
One thing that would dramatically reduce the node spillage might be a find node function - would be great to see it implemented
- Rich
Posted: Tue Oct 31, 2017 2:08 pm
by bepeg4d
Hi Rich,
maybe you already know, but now that the pickers are working in viewport, you can right-click on any node in the Node inspector panel, and choose "Show in Outliner" or "Show in Graph Editor".
ciao beppe
Posted: Wed Nov 01, 2017 5:56 am
by Jorgensen
@beppe
YES - that did fixed it.
Jorgensen
Posted: Fri Nov 03, 2017 1:52 am
by oscartung
gave it a try.
Loading proxy seem to crash SU, this did not occur in Octane Render for SketchUp 3.04.4.5 Stable Release
To be more specfic
1. Load proxy
2. open octane viewport (works fine)
3. close octane view port
4. reopen octane viewport (crash)
Posted: Fri Nov 03, 2017 10:01 am
by Jorgensen
it might just be me, but i find all the component and geometry groups and groups a bit disturbing - could they somehow be grouped or is there a deeper meaning as it is now?
jorgensen
Posted: Sat Nov 04, 2017 10:59 pm
by johlanga
Jorgensen wrote:it might just be me, but i find all the component and geometry groups and groups a bit disturbing - could they somehow be grouped or is there a deeper meaning as it is now?
jorgensen
Octane makes a lot of unnecessary nodes. This seems to crash Sketchup when using proxies. I can use proxies, but has to remove it and delete the nodes to the right of "Default View" (se picture).
Then its ok to save/open new file etc.
Posted: Sun Nov 05, 2017 6:21 pm
by johlanga
Where are the bug report thread? The one i found contains only 3 replies and the last one from Apr 2015.
Posted: Mon Nov 06, 2017 1:07 am
by haze
jorgensen
This is an artefact of implementation, because standalone was always intended to deal with the entire node graph, not a portion of it. This will be getting fixed soon.
Posted: Thu Nov 16, 2017 11:11 pm
by Jorgensen
are there something wrong with proxies? sketchup seems to crash every time i work with them.
not sure if i'm the only one experience crashes......
are you going to release updates more often?
thanks
jorgensen
Posted: Fri Nov 17, 2017 12:08 am
by azen
Jorgensen wrote:are there something wrong with proxies? sketchup seems to crash every time i work with them.
thanks
jorgensen
Hi Jorgensen,
Thus far, issues with Proxies are difficult to consistently repeat. Would you be able to supply an example of this crash? (perhaps a test scene if possible).
Cheers,
Azen
