Page 2 of 16
				Re: Version 3.07-R1 (Stable)
				Posted: Thu Oct 26, 2017 2:19 pm
				by FxDesign
				aoktar wrote:-Numbers on passes: Are you wanting that for single frame renders? I can't see any logic else of this to avoid it.
Not only for single frames, but for images sequences too.
My example for image sequences is:
Now we have:
MYRENDER_vertex normal_3_0001.exr
MYRENDER_vertex normal_3_0002.exr
MYRENDER_vertex normal_3_.....exr
or
MYRENDER_z-depth_2_0001.exr
MYRENDER_z-depth_2_0002.exr
MYRENDER_z-depth_2_.....exr
Can we have instead:
MYRENDER_vertex normal_0001.exr
MYRENDER_vertex normal_0002.exr
MYRENDER_vertex normal_.....exr
or
MYRENDER_z-depth_0001.exr
MYRENDER_z-depth_0002.exr
MYRENDER_z-depth_.....exr
Because if we add or remove a pass, all the actual number will change.
Example:
3_0001.exr >>>>> Will become >>>>> MYRENDER_vertex normal_
4_0001.exr
And we should change all the links in AE... Every time we add or remove passes, it could be very frustrating when we are making tests, or art direction.
I hope that's clearer
				Posted: Thu Oct 26, 2017 3:50 pm
				by toms.ubnt
				For the passes I would like to have more manual control, more like it is in Standalone version, where it is possible to manualy create file name structure.
				Posted: Thu Oct 26, 2017 4:25 pm
				by aoktar
				toms.ubnt wrote:For the passes I would like to have more manual control, more like it is in Standalone version, where it is possible to manualy create file name structure.
Ok I'll check for implementing a better customisation.
				Posted: Thu Oct 26, 2017 5:47 pm
				by Domenicozzo
				Love this release, thank you Ahmet.
Domenico
				Posted: Thu Oct 26, 2017 5:48 pm
				by thanulee
				Thank u very much, was looking forward for a stable version. Can i use this along with 3.07 standalone for network rendering? cheers
				Posted: Thu Oct 26, 2017 9:11 pm
				by zoppo
				thanulee wrote:Thank u very much, was looking forward for a stable version. Can i use this along with 3.07 standalone for network rendering? cheers
Yes.
				Posted: Thu Oct 26, 2017 9:35 pm
				by niestudio
				Hi Aoktar,
Does this
- Better Camera MotionBlur processing for fixing some issue of CamMoblur detection.
address this?
viewtopic.php?f=30&t=61168&p=313043#p313044
				Posted: Fri Oct 27, 2017 5:43 am
				by raulofs
				Thanks Ahmet for this release.
I report a little bug. When you lock the aspect ratio, X and Y are changed but not the Z.
				Posted: Fri Oct 27, 2017 6:04 am
				by Smyrkl
				I bought octane on the 21st, on the 25th I was using scatter and trying like hell to work out how to color the instances the same color as the driver image. And on my search for a tutorial found a release with exactly this feature. Now that's service... you read my mind.
Can someone point me in the direction of a tut on, or just explain how to use the new scatter features? The examples make use of Null objects? I want instance color from image like post above.
				Posted: Fri Oct 27, 2017 9:16 am
				by toms.ubnt
				aoktar wrote:toms.ubnt wrote:For the passes I would like to have more manual control, more like it is in Standalone version, where it is possible to manualy create file name structure.
Thanks! If you need any feedback I can give it.
By the way, loving the solo node feature!
