Page 2 of 2
Re: Problem with multi videocards render
Posted: Tue Nov 29, 2016 5:10 pm
by LightwaveGuru
slade wrote:Thanks juanjgon for the answers
I actually have two monitors connected to a video card, so I'll try to disable the GPU connected to the monitor and watch what happens
LightwaveGuru If I do not succeed to render the scene (with 3 cards), I send to you the scenes, so you can do a few tests
ok. we will find the failure!
snip lwguru
Posted: Sun Dec 04, 2016 4:44 am
by LightwaveGuru
juanjgon wrote:You should test each GPU one by one to see if any of them has a hardware issue. Update the drivers if they are too old also can help.
If used one by one all the GPUs work fine, but with all enabled Octane crashes, perhaps the problem is related to the PSU, that can have not enough power for all the GPUs, or it could have also a hardware problem.
You can enable the log file in the plugin options panel to see if there is any report about CUDA errors.
Problem is solved. I test the scene from slade with 4x titan x 12 gb vram (maxwell)
triangles = 20542317
GPU Used = 8372
GPU free = 1609
sys ram used 35,97 gb!
anybody remember if i say that 32 gb sys ram is not enough
hi slade,
put 32 gb sys ram more in your computer! the reason is not octane. the reason is this monster scene himself!
(check the testrender in your PM)
snip lwguru
Posted: Sun Dec 04, 2016 3:16 pm
by slade
Thank you LightwaveGuru I'll try to contain the polycount in the future
Posted: Tue Dec 06, 2016 10:54 am
by LightwaveGuru
slade wrote:Thank you LightwaveGuru I'll try to contain the polycount in the future
snip lwguru
