Page 2 of 5
Re: Octane Render for SketchUp 3.04.4.7 Test Release
Posted: Fri Nov 25, 2016 8:58 am
by smicha
haze wrote:smicha, my mistake - Marcus just told me this will only work in the release version, because the demo version does not have the OCS reader.
Thanks haze. Good to know it works in the official release.
Posted: Fri Nov 25, 2016 10:33 am
by -rb-
haze wrote:-rb- wrote:Hi Captain,
Plugin opens in Demo mode - can't log into license as 'License' window won't pop up when clicked
- odd!
- Rich
Hi, could you let us know what OS and what version of SU you are using? Thank you
Hey Haze,
SU 2016 Pro, Windows 10 Pro
Posted: Sat Nov 26, 2016 12:15 am
by fivebythree
Nice work.
Probably won't use it, though. SketchUp orbx open in standalone has become my way to get the most out of Octane including the coveted nodal.
Posted: Sun Nov 27, 2016 8:01 pm
by haze
fivebythree wrote:Nice work.
I'd be keen to know more about what would suit you best for the SU plugin. Our roadmap includes the ability to do everything that standalone node graph editor allows (incl geometry etc). We are also planning an overhaul of the UI by using the same UI toolkit as standalone. We'll be investigating whether we can share UI elements between the SDK and the plugin - this should solve many issues we have with Flash currently. Please let me know your thoughts here or via PM
Posted: Sun Nov 27, 2016 8:32 pm
by Jorgensen
Is it intended that i can't work in sketchup while the node editor is open?
Posted: Sun Nov 27, 2016 8:55 pm
by haze
Jorgensen wrote:Is it intended that i can't work in sketchup while the node editor is open?
This is the main reason why we are removing the Flash layer - it's a limitation of the current message loop system. We thought to prioritise the UI overhaul over the node graph improvements, but we couldn't remove the Flash material editor without doing so. At this point it is looking more likely that we will work more towards the overhaul and not release incremental updates of it since the workflow is not as easy as we would like it to be
Please do keep sharing your thoughts on this
Posted: Sun Nov 27, 2016 9:02 pm
by smicha
haze wrote:Jorgensen wrote:Is it intended that i can't work in sketchup while the node editor is open?
Haze,
In Modo Paul coded the node editor from the Standalone so that it is being closed automatically whenever you click in the Modo area.
Posted: Sun Nov 27, 2016 10:36 pm
by haze
Thanks smicha, I'll see if we can incorporate this as well
Posted: Sun Dec 04, 2016 4:58 pm
by Jorgensen
Should proxies work with this release?
I rightclick on a component > octane proxy > From... and then i select my .orbx file and the component disappears and noting is shown...
I can open the .orbx file in the standalone - and it renders fine.
Can anyone tell if the proxies should work?
thanks
jorgensen
Posted: Sun Dec 04, 2016 7:35 pm
by smicha
Jorgensen wrote:Should proxies work with this release?
thanks
jorgensen
IMO proxies shall be functional through the new nodal approach with full support for obj, ocs, orbx nodes. As Azen said - they are working on it.
