Page 2 of 19
Re: Version 3.04-R1 (19.10.2016) - TEST
Posted: Wed Oct 19, 2016 5:18 pm
by aoktar
atome451 wrote:For your information, there is no node anywhere for the "W Coor" in the Node Editor interface.
By the way, it works fine if you add the "W Coor" node from the standard C4D material editor. Not a big problem then... :roll:
Thanks! I could just did such until now. I didn't wanted to hold a release which is important for someone.
Posted: Fri Oct 21, 2016 2:50 am
by carterner
the light pass is different with old version
Posted: Fri Oct 21, 2016 2:51 am
by abstrax
carterner wrote:the light pass is different with old version
That's a bug I introduced in 3.04, which will be fixed in 3.04.1 which we are building right now.
Posted: Fri Oct 21, 2016 5:13 am
by carterner
thank you
Re: Version 3.04.1 (22.10.2016)
Posted: Fri Oct 21, 2016 10:02 pm
by aoktar
Version 3.04.1 is up now. Enjoy it!
Posted: Sat Oct 22, 2016 12:48 pm
by KonstantinosD
Something is wrong in this version, this is the same render after 1min 6 sec on my system on both renders. You can see the first one is clear and light is nice 3.04, but in the second one 3.04.1, the light is all messed up and very noisy on the same time/samples.
I also provide the scene but without the floor texture.
first,
second,
scene,
https://dl.dropboxusercontent.com/u/348 ... 20test.rar
Thanx,
Posted: Sat Oct 22, 2016 1:56 pm
by artdude12
I tried both versions as well and am getting the same results.
C4D R18
Posted: Sat Oct 22, 2016 2:09 pm
by aoktar
artdude12 wrote:I tried both versions as well and am getting the same results.
C4D R18
Do you mean same wrong results or same on both versions 3.04 and 3.04.1?
Posted: Sat Oct 22, 2016 2:36 pm
by artdude12
3.04 is rendering the file like the first image that KonstantinosD posted.
3.04.1 is rendering the file like the second (darker) version.
Both with R18
Posted: Sat Oct 22, 2016 3:05 pm
by KonstantinosD
Also, when i test the scene on the latest standalone it renders fine, in C4D it is much much darker for some reason and as you can see noisy and wrong. It seems like the exposure is messed up.
