Page 2 of 3
Re: Render Queue saves allways two files
Posted: Thu Sep 29, 2016 9:42 pm
by aoktar
proundkontra wrote:aoktar wrote:Well thanks. I could reproduce the issue. My first idea it's not about plugin than a C4D issue. I don't write any images from plugin else of saving the pass images.
So there is no other, more comfortable way to it? Because if you not only write images throug the plugin but also through the c4d save dialog you have to change names allways on two places.
Especialy if you have many takes with different rendersettings you end up changing a lot of stuff every time you versioning up.
To me it would be a huge timesaver.
It's not a plugin related issue. That's not clear to me why you think that's an octane issue. It's clearly happening after doing render by standard renderer. See image.
Posted: Tue Dec 13, 2016 7:18 am
by zinogino
Has there been any solution for this till now? Already disabled c4d render and it still renders out two seperate files when using render queue
Posted: Tue Dec 13, 2016 11:42 pm
by aoktar
zinogino wrote:Has there been any solution for this till now? Already disabled c4d render and it still renders out two seperate files when using render queue
Do you read my above post?
Posted: Wed Dec 14, 2016 3:18 am
by zinogino
aoktar wrote:zinogino wrote:Has there been any solution for this till now? Already disabled c4d render and it still renders out two seperate files when using render queue
yeah...uncheck everything
Posted: Wed Dec 14, 2016 8:43 am
by aoktar
zinogino wrote:aoktar wrote:zinogino wrote:Has there been any solution for this till now? Already disabled c4d render and it still renders out two seperate files when using render queue
It's not octane issue.
viewtopic.php?f=30&t=56534&start=10#p290361
Posted: Wed Dec 28, 2016 5:01 am
by crowellster
Just to doublecheck that I understand, here: there is indeed no workaround on this? I understand that it's not an Octane issue per se, though if perhaps we could use the built-in multipass saving system then we wouldn't have this issue, right?
Justin
Posted: Sun Feb 19, 2017 4:38 am
by zinogino
crowellster wrote:Just to doublecheck that I understand, here: there is indeed no workaround on this? I understand that it's not an Octane issue per se, though if perhaps we could use the built-in multipass saving system then we wouldn't have this issue, right?
Justin
I guess so, have to manually delete the files lol
Posted: Mon Mar 06, 2017 5:38 pm
by slepy8
I have a workaround for you.
Create a folder. I call it "dump".
Save your octane renders to your project folder as set in "render passes" tab as you do already.
but
ENABLE native C4D saver and direct it to this "dump" folder.
Now you save two images. One from Octane saver and another from C4D saver.
After rendering finishes, just go to dump folder, Ctrl+A and 'del'.
If you render multiple projects via Render Queue, in the end you'll just have to clean this "dump" folder without messing around in the cinema files folder.
Easy and fast way.
Peace!
Posted: Sun Oct 08, 2017 2:06 pm
by thanulee
I have the exact same issue and is really annoying.
It happens only if u use RENDER QUEUE from c4d, thats whats not clear in ur description am i correct?
Steps to reproduce:
- Setup ur octane render settings in RENDER PASSES, where to save etc etc. (see image 1)
- Completely disable the SAVE in c4d render settings. (see image 1)
- Add to render queue the scene. (see image 2)
- Render queue doesnt start unless u specify a location and there is the extra files that are not needed. (see image 3)
Therefore octane needs somehow to take over render queue settings.
Pls a solution is required, its a very bad workflow.
thanks
Posted: Sun Oct 08, 2017 4:38 pm
by slepy8
Read my above post!
You wan't avoid this. And it's not the Octane nor C4D issue. It's not an issue at all!
Just follow my steps to have clean project folder.
I do it all the time. And what you need in the end is just cleaning the "dump" folder (or however you call it).
