Page 2 of 7
Re: Phantom Architecture [concept] Displacement fix revealed!
Posted: Mon May 23, 2016 9:44 pm
by rappet
Way to go Phantom! Marvelous it will be
Posted: Tue May 24, 2016 10:30 am
by realistic-design
Hello Phantom107,
First of all, great work!
About the displacement fix/edge/smooth issue, you don't have to subdivide the surface so much to fix the smooth problem on the flat surfaces. You just need 1 cut after the rounded edge, in the flat part. That will fix the problem adding only a very unsignificant number of polygones!
In other words, in the case of your cube, a 1mm bevel on each flat polygones will fix it.
Raph
Posted: Tue May 24, 2016 3:08 pm
by Phantom107
Thanks for your input Raph, though I am actually well aware of this, That analysis is not how I will be making the algorithm, it was just a proof-of-concept, I am still trying out different options.
I should note that bevel is actually not the way to go here, it introduces a LOT of potential problems... from going badly because of possibly incorrectly made geometry, or going bad when surfaces are too thin... it will also not work on surfaces that are in any way bent (like an arc shaped wall).
I'm trying to cook up a solution that works for everything.
Posted: Wed May 25, 2016 9:31 am
by realistic-design
Phantom107 wrote:I'm trying to cook up a solution that works for everything.
AMEN to that
Posted: Sun Jun 05, 2016 11:07 pm
by Phantom107
The displacement fixer algorithm for the upcoming Phantom Architecture software is now functional!
It takes your architecture mesh, then adaptively tessellates the surfaces of materials you pick, then fixes the normals for you automatically and exports as another *.OBJ file.
Massive timesaver!
Picture 1: result with displacement in Octane Render
Picture 2: wireframe view in Octane Render
Picture 3: source *.OBJ model (SketchUp)
If you look at the wireframe image, yes even complex corners are supported, as long as you properly model the geometry!
Phantom Architecture is planned to feature 3 major tools (the displacement fixer algorithm is one of them) and one minor tool. All will greatly assist your architecture rendering workflow.
The Phantom Architecture website is not yet live.
Phantom Technology Suite licensees will get it before the official standalone-licensable release.
Posted: Mon Jun 06, 2016 3:14 pm
by Marvez
Posted: Mon Jun 06, 2016 10:35 pm
by rappet
Looks phantomenous
Posted: Tue Jun 07, 2016 4:22 pm
by JonathanWinbush
Your doing great work I run into this problem alot I'll be a day one user for sure when its available
Posted: Tue Jun 07, 2016 7:37 pm
by Phantom107
JonathanWinbush, if you have any other annoying problems, send me a PM and I might be able to think of a solution (if I hadn't already planned on it
Posted: Tue Jun 07, 2016 7:56 pm
by itsallgoode9
would this work at all with CAD models for products or does the geometry need to be clean before your new tool is used?
