Page 2 of 2
Re: Missing light reflections on glass
Posted: Fri Oct 23, 2015 8:15 pm
by face_off
nother question: If I move the camera farther away I loose the light reflections. Why is that so?
Is that really happening - or are the reflections just too small to see You would need to increase the render resolution to check this. Also - if you have hotpixel set to 0, it might be removing the reflections if they are very small. Also, check you Kernel->Filter Size and Caustic Blur settings.
Posted: Sun Oct 25, 2015 4:07 pm
by xanathon
I rendered in 4k and if I view the image in full resolution and close up the lights on the glassware are gone, so, yes it's really happening. :)
Here is an image detail from the 4k version:
Hotpixel is not 0. I will test your suggestions regarding filter size and caustic blur. Thanks again.
Posted: Sun Oct 25, 2015 10:35 pm
by face_off
Maybe as you move the camera back, the lights are moving out of reflection visibility (ie. something is in front of the lights when the camera's position changes).
Posted: Sun Oct 25, 2015 11:54 pm
by Zay
No shadows indicates your lights are not on.
Posted: Mon Oct 26, 2015 11:59 am
by xanathon
The lights are on, it's the same scene as before, just the camera was moved back.
Posted: Wed Oct 28, 2015 1:52 pm
by xanathon
Thanks again for your help, I managed to get the reflections back with some more parameter tweaking and repositioning and refocussing of the camera.
