Re: Beeple Zero Day Render Speeds?
Posted: Mon Oct 05, 2015 12:31 am
I had help from Lewis, and I read and re-read the Video Cards & GPU section over and over again, until I understood the discussions and was able to spec out what I wanted. The case is actually a little small, but only because the design splits the interior volume on the horizontal. That makes the placement of the (future) pump and reservoir a little tricky. Right now, I am using two Corsair CPU coolers, which are bulky. These will be replaced with a cleaner setup when I install the cooling radiators and loop. That will free up a bit more space, though I plan on at least two 3 unit radiators for the cards, and another 2 or 3 unit cooler for the CPUs.
The power supply is in my sig as well. It is 1600 watts, and should be enough for my intended set up. Fortunately, there is plenty of room for another PS if needed, and this case has the option of a pedestal if I need even more room. Gotta love CaseLabs. Not cheap, but more than enough options!
If you're getting into this, take your time. I researched for over a month before I purchased anything, and I used everything I bought, save for GPU card 4, which is awaiting the water cooling system. I wanted all four cards to be the same, that is why I purchased them at the same time. FYI, I wish I would have gone with the Titan X over the GTX 980 Ti's, but only because of the memory headroom. I have already hit the limit a couple of times now, though judicious scene editing made it fit. Even so, this box is also a simulation (and comp) box for TFD and Marvelous Designer (one of the ways I justified the $ and config...). TFD rocks with GPU cards, but if you max out on memory, it crashes instead of exiting gracefully
