Page 2 of 3
Re: OctaneRender™ 2.1 for LightWave™ - build 2.12.0
Posted: Sun Oct 26, 2014 8:00 pm
by juanjgon
BorisGoreta wrote:It says coerent mode instead coherent mode in render kernels.
This problem is easy to fix
Posted: Sun Oct 26, 2014 8:11 pm
by BorisGoreta
Not on sunday evening it's not
Posted: Tue Oct 28, 2014 5:48 am
by OlaHaldor
I downloaded this 2.12.0 version, but the file name in the ZIP is 2.10 ?
I just found that a little strange, but perhaps it's just me being new to Octane and new to the naming conventions.
Posted: Tue Oct 28, 2014 8:20 am
by vipvip
Just a little problem encountered randomly:
there is some strange behaviour around the camera response postprocess with IPR: it applies the change them but after timeline scrubbing, the response come back to initial setting: same thing happenened one time some days ago with the vignetting setting...
As said it first, the problem is not systematic and happens randomly, i don't have the time actualy to track this deeper because of work, but if it becomes more precise i'll let you know...
Posted: Tue Oct 28, 2014 9:00 am
by juanjgon
OlaHaldor wrote:I downloaded this 2.12.0 version, but the file name in the ZIP is 2.10 ?
The .p files are going to have the "2.10" suffix for all the 2.1x releases. This is the base version (that should be only 2.1 to avoid confusions, but I don't want to change it now).
You can check in the "About" window the current plugin build that you have installed in your Layout.
Posted: Tue Oct 28, 2014 3:24 pm
by juanjgon
BorisGoreta wrote:
Network settings are not saved. Everytime I start LW I need to change the subnet mask to the second one, activate network rendering and select the node.
Boris, can you please test the last daily build (2.12.1)? ... there is a fix in the network software that perhaps could fix also your problem.
Posted: Tue Oct 28, 2014 3:58 pm
by BorisGoreta
It works ! Excellent ! Thanks for the fix !
Posted: Tue Oct 28, 2014 6:40 pm
by 3dworks
very nice update! still missing a time to completion estimation for all frames, when rendering animations...
this would be a feature request, i guess
cheers
markus
Re: OctaneRender™ 2.1 for LightWave™ - Production release
Posted: Mon Nov 10, 2014 4:48 pm
by BorisGoreta
I have noticed that if I have a full 720p image rendered with 1000 samples it takes 2.5 minutes to finish the frame, but if I set limited region to onlz bottom half of the frame then again it takes 2.5 minutes.
Posted: Sun Nov 16, 2014 1:26 pm
by Builtdown
Boris, I have understood that if you render only half of the picture, you should set the samples to 500 instead 1000.
