Page 2 of 3
Re: Hair tips cut off
Posted: Thu Sep 11, 2014 12:33 pm
by coilbook
MistAjuliax wrote:flyaway result
sorry i found an option in display to show more than 10,000 Thanks again
Posted: Thu Sep 11, 2014 1:45 pm
by suvakas
Interesting. I didn't know it works like that.
Thanks a lot for the tip !
Suv
Posted: Thu Sep 11, 2014 1:49 pm
by suvakas
coilbook wrote:
Thanks Suvakas
So if I but a real hair plugin it will work with octane
It has been talked about.. search the forum and you should find some conversations about it. I think Ornatrix was supported?
Since I don't have any hair plugins, then I don't know how good the integration is. I do know, that plugins use Octane hair primitives instead of geometry.
Suv
Posted: Thu Sep 11, 2014 2:47 pm
by MistAjuliax
suvakas wrote:MistAjuliax wrote:flyaway result
Suv
De nada
I forgot to notice that dynamics live works too. I will test some more and share results.
Regards.
Posted: Thu Sep 11, 2014 6:52 pm
by MistAjuliax
Another test ... i have to precise that primitive used is a cone primitive, and height segment has to be different from 1 otherwise it cannot be bend by parameters. Here heigth segment is set to 6.
Posted: Fri Sep 12, 2014 7:42 am
by HHbomb
hey guys, are you able to see hairs in octane viewport, or just in render window ?
In max 2015 I remember that I can see hairs in octane viewport, but not anymore...
Posted: Fri Sep 12, 2014 7:56 am
by suvakas
Hey Mist, how can you assign a separate material to teapot?
Mine always gets the same material as the instanced object has.
Suv
Posted: Fri Sep 12, 2014 8:24 am
by MistAjuliax
suvakas wrote:Hey Mist, how can you assign a separate material to teapot?
Suv
Hi Suv,
First i create a teapot and a primitive, here a cone. I assign a different material on each object, then pick up the cone in instance node and i open octane viewport. These are the steps i use, nothing else.
I specify that i use 3ds max 2015 extension 1.
Posted: Fri Sep 12, 2014 1:54 pm
by coilbook
HHbomb wrote:hey guys, are you able to see hairs in octane viewport, or just in render window ?
only if i go to hair and fur effects and set type to geometry
Posted: Fri Sep 12, 2014 5:22 pm
by HHbomb
arggghhh ! Hair and fur in geometry don't work.....
