Page 2 of 4
Re: Octane Materials. Questions thread.
Posted: Fri Aug 29, 2014 7:13 am
by linvanchene
edited and removed by user
Posted: Fri Aug 29, 2014 7:20 am
by Sighman
For a three card setup I would plug my monitors into one card and use the other two for rendering. As Tugpsx suggests I would Activate one card at a time to determine which one the monitors are plugged into. Then deactivate the one you are using for the monitors and activate the other two without priority.
If you want to use all three then enable priority only on the monitors card but you will loose some memory if you do.
- Multi-Card Setup
Posted: Fri Aug 29, 2014 7:41 am
by SciFiFunk
linvanchene and Orion_UK
Thanks. Texture Emission. Forgot about that (bit rusty having taken a break from Octane for a month or two before the Carrara release).
Changing the scene parms to up the lighting to compensate, that's a good idea linvanchene thank you.
Posted: Fri Aug 29, 2014 2:33 pm
by Tugpsx
Here is a TV Screen test
- TV Screen test
Posted: Fri Aug 29, 2014 2:38 pm
by SciFiFunk
Excellent effect on the screen it's self Tugs.
Posted: Fri Aug 29, 2014 2:57 pm
by orion_uk
SciFiFunk wrote:Excellent effect on the screen it's self Tugs.
Could not agree more, nice one Tug
Also, imagine how much better this would be when Sighman adds animated PNG sequences ( a recent request of mine) ..
That would (if possible) bring the screen to life even more
Posted: Fri Aug 29, 2014 3:04 pm
by orion_uk
A big thank you to you all for sharing more info regarding multiple cards, Glad I did have things hooked up as I 'should' have
Also, thanks for the tips on determining which of my cards in the list is using which monitor, I will check this out when I get home tonight
Posted: Fri Aug 29, 2014 7:44 pm
by Tugpsx
Thanks guys, I have to finish my animated texture script for standalone. I haven't worked on it in a while.
- Animated Texture Script
Posted: Sat Aug 30, 2014 12:01 am
by Tugpsx
Playing with more textures Octane Grass.
- Back yard
Posted: Sat Aug 30, 2014 9:31 am
by orion_uk
Ohh, like the sound of that
Been quite a while since I used the standalone let alone look at the scripts! Last script I looked at was the turntable one
The grass is coming along great Tug, keep it up mate
Here is a quick test with PySwarm..
http://render.otoy.com/forum/viewtopic.php?f=79&t=42152
