Page 2 of 2
Re: hypershade no longer opens without octane
Posted: Fri Mar 20, 2015 1:24 pm
by zboog
@JimStar, your explanation sounds reasonable, but if this is a Maya limitation then how come V-Ray and Arnold don't break the hypershade when they're unloaded?
Posted: Fri Mar 20, 2015 1:48 pm
by jangwee
rslaverne wrote:Just curious, what were the two lines of code you used to temporarily fix this? If you don't mind sharing.
-Will
@rslaverne,
The 2 lines of code are from earlier in the thread where Jim suggested a workaround to remove the option variables that are causing the problem.
optionVar -remove "renderNodeTypeTreeInitializeUserProc";
optionVar -remove "renderNodeTreeInitializeUserProc";
Wenneker's solution was adding the the code to mel script to run at startup every time you open Maya.
I just copied those lines to custom shelf button so it only does it when I want it to.
Either way works.
Posted: Fri Mar 20, 2015 1:51 pm
by jangwee
zboog wrote:@JimStar, your explanation sounds reasonable, but if this is a Maya limitation then how come V-Ray and Arnold don't break the hypershade when they're unloaded?
Yeh my thoughts exactly.
@Jim - It's probably safer to not fix by hack the Maya startup code as you suggested.
Last thing you want to do is introduce other workflow/pipeline problems to then require troubleshoot or fix.
If this is really a bug in Maya, have you logged bug report to Autodesk about it?
Again, I wonder how other third-party render plugins are getting around this problem.
Is there another way to add Hypershade functionality on plugin initilisation?
Posted: Sat Mar 21, 2015 5:25 am
by JimStar
OK guys, it's solved.
I've found one more way how to do this safer. Just checked it - no problems neither with other plugins nor with hypershader.
Will be released in next version.
Posted: Sat Apr 04, 2015 10:24 pm
by dsyee
Any update on when this might come out?
