Page 2 of 3
Re: No RenderTarget setting?
Posted: Fri Jul 18, 2014 1:34 am
by face_off
One issue that is a red flag is its looking in the wrong instalation folder for thsoe files it's failing to find. where can I change the location?
Ignore the reference to Poser Pro 2014 in the error message - this is simply the folder where the python code was compiled (ie. MY pc, not yours).
1) What folder is Poser10 installed into?
2) What was the full folder name where you went looking for the rendertarget.por file pls?
3) Are you using the English version of Poser?
This is most probably a corrupt PoserPython installation in Poser 10, but I just want to discount some other things first, which the above info to tell me.
Posted: Sat Jul 19, 2014 4:45 pm
by Biffo
Yes it's giving me a pickel python error as follows:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 603, in EventOpenViewport
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5269, in RefreshSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\RenderManager.py", line 98, in GetCurrentRenderTargetNode
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\ViewManager.py", line 51, in GetDefaultSceneRenderTargetNode
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\ViewManager.py", line 215, in MenuCommand_LoadFromDefault
File "F:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\lib\pickle.py", line 1378, in load
return Unpickler(file).load()
File "F:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\lib\pickle.py", line 858, in load
dispatch[key](self)
File "F:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\lib\pickle.py", line 880, in load_eof
raise EOFError
EOFError
Posted: Sat Jul 19, 2014 10:06 pm
by Biffo
1)
2)
C:\Users\Ben\AppData\Roaming\Poser\10
3)Yes english version.. Thanks Paul.
Posted: Sat Jul 19, 2014 11:16 pm
by face_off
Thanks. So you have Windows 64bit. but running 32 bit Poser 10? But you also have Poser Pro 2014 64bit demo installed? If this is correct - can you pls confirm that you downloaded and installed the 32 bit version of the Octane 2 plugin? And that you installed it into F:\Program Files (x86)\Smith Micro\Poser 10? (To confirm, you should have a file
F:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\addons\OctaneRender for Poser\2-32\octane.dat).
Can you pls confirm the above? In the meantime, I will double check the 32 bit Octane 2 plugin installer.
Posted: Sat Jul 19, 2014 11:26 pm
by Biffo
That's right, Paul. I isntalled the demo of poser pro 2014 but didn't buy it. I bought the Poser 10 version. There is a Octane.dat file dated 7/1/2014 installed in the folder structure:
TIA!
Posted: Sat Jul 19, 2014 11:29 pm
by face_off
Thanks - I will install Poser 10 and check the 32 bit installer and get back to you.
Posted: Sun Jul 20, 2014 12:18 am
by Biffo
You're the best.
Posted: Sun Jul 20, 2014 10:15 am
by face_off
Biffo - I have installed the plugin (release 2.3.0.22) into Poser10 (32 bit) and Poser Pro 2014 (32 bit), and it woulds fine on both. So I think the error you are getting is due to corrupt PoserPython installation. I suggest the following:
1) Uninstall Poser Pro 2014 demo
2) Re-install Poser 10
3) Re-install all the Poser 10 SR's (3.1)
4) Re-install OctaneRender for Poser 32 bit
Posted: Sun Jul 20, 2014 5:23 pm
by Biffo
OK. Giving it a shot.
Posted: Sun Jul 20, 2014 6:03 pm
by Biffo
Nope. Did not work. Exact same error messages as before:
