Page 2 of 3
Re: "failed" error on 780ti
Posted: Thu Feb 27, 2014 1:03 am
by aw1
shader ball is working.. trying with materials and it seems to work fine..
Posted: Thu Feb 27, 2014 1:05 am
by aw1
i just made a new PC with this 780ti.. installed all latest driver from nvidia..
Posted: Thu Feb 27, 2014 1:06 am
by aw1
ok the Shaderball failed too !!! yes i restarted the computer too!
here is the log:
Started logging on 26.02.14 19:56:28
CUDA error 715 on device 0: Error code unknown.
-> Kernel execution failed (pmc)
CUDA device 0: PMC failed
Posted: Thu Feb 27, 2014 1:12 am
by JimStar
GPU overheat?..:?
Posted: Thu Feb 27, 2014 1:13 am
by aw1
how do i find out that gpu is is heating? is there anyway?
Posted: Thu Feb 27, 2014 1:14 am
by abstrax
aw1 wrote:ok the Shaderball failed too !!! yes i restarted the computer too!
here is the log:
It looks like a hardware issue to me. If this is a new 780Ti, then I think the card is broken and you should ask for a replacement. If not, it could be anything, like the motherboard or memory or the power supply. To be sure that it's not a driver issue, you could install an older graphics driver, but my bet is currently on a hardware problem.
Posted: Thu Feb 27, 2014 1:15 am
by abstrax
aw1 wrote:how do i find out that gpu is is heating? is there anyway?
There are several tools out there. Just search the Internet for "gpu monitor".
Posted: Thu Feb 27, 2014 1:21 am
by JimStar
aw1
+1 for hardware.
New computer, new GPU, and error looks like hardware problem...
But you may not notice the overheat if e.g. there is a bad connection between GPU processor and cooler (e.g. no termal paste, or something between them...). In this case the overheat may be reached so quickly, that you will not notice it in the tools before GPU stops...
Just IMHO...
Posted: Thu Feb 27, 2014 8:06 am
by Zay
You can use GPU-Z to monitor your graphic card:
http://www.techpowerup.com/downloads/23 ... -z-v0-7-7/
Posted: Thu Feb 27, 2014 8:41 am
by gabrielefx
check your gpu with another gpu based renderer.
