Page 2 of 2
Re: Camera animation export
Posted: Wed Jan 15, 2014 12:34 pm
by face
Yes, you´re right, but for now i have also much work to update the internal plugin...
But maybe, when i have a kind of boredome, i will change something ;)
face
Posted: Wed Jan 15, 2014 2:42 pm
by manalokos
The internal plugin would be much more powerfull if we were able to use the Octane tree at the same time.
Once the plugin is compatible with ICE particles I might consider purchasing it.
Regarding the converter, I think it is an important tool as the Octane standalone has a workflow that I now consider much faster than using and manipulating materials in the Softimage render tree, and I've been a Softimage user for 16 years. :)
Thanks for your work.
Kind regards
Filipe
Posted: Wed Jan 15, 2014 8:00 pm
by face
I think this is a problem with Softimage itself.
Each time you change something, the renderer is stopped and some things would be evaluated.
This are the cameras, meshes, each shader and i don´t know what more...
Is found what is changed, the equivalent in the Octane "sandbox" will also changed and the renderer will begin to render.
That´s why you can´t never get the same fast feedback which you have in Octane.
ICE will be one of the next things i will implement, when the current integrated capabilities are working good.
Now i will implement the motion blur feature and then i will update all texture mappings.
This things are working in a testing manner.
This means, some values are hard coded without an UI, or some textures have the new mapping, but not all.
Also more a stupid work, to copy and paste code between the lines...
face
