Page 2 of 3
Re: Render skipping frames issue
Posted: Thu Sep 03, 2015 10:20 pm
by CCIDgfx
The issue is skipping frames while rendering. I'm sure it's a setting somewhere. This is a fairly new computer with all new parts.
Posted: Thu Sep 03, 2015 11:05 pm
by aoktar
CCIDgfx wrote:The issue is skipping frames while rendering. I'm sure it's a setting somewhere. This is a fairly new computer with all new parts.
Which frames are skipping? Can you show me a screen with picture viewer history? We have some debugging options to check it.
Posted: Thu Sep 24, 2015 5:39 pm
by CCIDgfx
It's still happening and I'm on a pretty tight deadline to finish this project an I have to keep restarting my renders.
Posted: Thu Sep 24, 2015 6:28 pm
by aoktar
CCIDgfx wrote:It's still happening and I'm on a pretty tight deadline to finish this project an I have to keep restarting my renders.
you have two option to get my help, please choose one:
1-Describe very well the scene content and render settings.
2-Send me the scene to check
Posted: Thu Sep 24, 2015 7:19 pm
by CCIDgfx
Here is the scene I'm trying to render
Candy Bin_All_0001.zip
(5.48 MiB) Downloaded 191 times
Thank You
Posted: Thu Sep 24, 2015 7:55 pm
by aoktar
CCIDgfx wrote:Here is the scene I'm trying to render
Thank You
I'm checking. On which frame does it start to skip frames? Is it happening after a spesific frame? Also what's your driver version?
Posted: Fri Sep 25, 2015 9:40 pm
by CCIDgfx
I have the latest Nvidia drivers and I'm using the latest version of Octane plugin.
It usually does it around the 7th or 8th frame. It will do it twice then I can get it to go for a bit longer. But I can never render a full scene without the skipping frames.
Posted: Fri Sep 25, 2015 10:04 pm
by aoktar
CCIDgfx wrote:I have the latest Nvidia drivers and I'm using the latest version of Octane plugin.
I have tried to test it. Working as expected. I suppose there can be a problem on Renderer side as a crash or Cuda error. Have you checked the Script->Console output or LiveViewer->Help->Octane Log after this skipping happened? Anyway i'll try to check more to see somethings.
Posted: Sat Sep 26, 2015 7:57 pm
by CCIDgfx
I'll check those next time it happens and post the log for you to look at =)
Thank You
Posted: Sat Sep 26, 2015 9:05 pm
by CCIDgfx
Here are the log files for the most recent skipping issue
octane 2.24.1 150926 170055.log
(9.91 KiB) Downloaded 156 times
