Page 2 of 11
				Re: OctaneRender® for 3ds max® v1.0 beta 3.00[Test]
				Posted: Thu Jul 19, 2012 7:27 pm
				by mbetke
				As far as I understood the series 5XX is still best for Octane because the 6XX isn't optimized. At the moment the GPU industry around Nvidia is a bit strange.
				Posted: Thu Jul 19, 2012 9:00 pm
				by bicket
				Hi super_Karba
Thanks alot : i'll be able to render big scenes with only a 1.5Gb card
				Posted: Thu Jul 19, 2012 9:23 pm
				by Karba
				jan kudelasek wrote:
It look like that collorcorection have a problem. dont display any changes in mtl editor and oc viewport.
Fixed, wait for a new release.
				Posted: Thu Jul 19, 2012 9:34 pm
				by Karba
which tool did you use for the scattering the grass? Multiscatter?
I used multiscatter.
It is not supported directly.
I had to generate more than 40k objects in my scene and have extremely slow viewport.
				Posted: Thu Jul 19, 2012 10:52 pm
				by acc24ex
				feels like christmas
can't wait to try it out
OK now what is the best way to set up grass, sharing some scenes would be quite beneficial now, give us a test scene
Here's a bug from before, if you already have octane assigned as the render, and choose a render preset that has an octane preset - every preset in render window is shown twice.. I had the render settings opened at the time - this happened on the previous version as well.. - it fixes itself if you close and open the render settings again
				Posted: Fri Jul 20, 2012 5:08 am
				by Karba
				acc24ex wrote:feels like christmas
Unfortunatelly I don't have any good sample sceen with grass. I will prepare some thing.
				Posted: Fri Jul 20, 2012 5:10 am
				by Karba
				Usefull material for windows glass based on glossy material and falloff textrue.
It allow to pass light even with diret light kernel or sun light.
				Posted: Fri Jul 20, 2012 6:38 am
				by gabrielefx
				Thank you Karba for your work.
I would like to switch between 2.8 and 3.0 without uninstall both.
Is it possible?
				Posted: Fri Jul 20, 2012 6:43 am
				by Elvissuperstar007
				я не интегрировн пока-что. но есть один неприятный момент!  полезная функция конвертер материалов. он  видимо работает только для интеграциии!  пару раз пытался сконвертировать. все нормально . но стоило зайти в мат эдитор ..3д мах  просто вылетал! мне хотелось посмотреть настройки шейдеров  вирей в октан !  для пополнения онлайн библиотеки. интеграцию прикуплю в скоре , хотя в максе работать не охота
				Posted: Fri Jul 20, 2012 6:46 am
				by Karba
				gabrielefx wrote:Thank you Karba for your work.
Is it possible?
You can install another 3dsmax. If you have 64x, you can install 32x
