Page 2 of 3
Re: yacht cabin
Posted: Thu Feb 16, 2012 3:10 pm
by madcoo
Absolutely amazing... as usual !!!
Great work, well done !
Re: yacht cabin
Posted: Thu Mar 22, 2012 6:34 am
by rfox
Just a quick question...
How do you achieve 360 panoramic render with octane?
would you mind to share your secret here?
Re: yacht cabin
Posted: Thu Mar 22, 2012 8:18 am
by madcoo
@ rfox -> I think he used Panotour for the virutal visit.
So he might have used Panoview (I think that's the name) which is the "'other part" of Panotour that enables you to tile several images into a 360° single image.
Is that right Gabriel?
Re: yacht cabin
Posted: Thu Mar 22, 2012 9:55 am
by gabrielefx
pano2vr
I rigged 6 cameras
Re: yacht cabin
Posted: Fri Mar 23, 2012 9:08 am
by KaroBastardKiter
you can clearly see it's a cube tho. isn't there a way to achieve a better result?
Re: yacht cabin
Posted: Fri Mar 23, 2012 3:51 pm
by rfox
Thanks guys for the hints
I was trying to figure out how to set up the camera of 6 views there since octane doesn't support pano camera at this moment. I tried to use octane render of my interior with pano exporter from 3ds max but no luck. is there a good way to achieve the right camera to get it on 3ds max?
Re: yacht cabin
Posted: Fri Mar 23, 2012 8:15 pm
by bepeg4d
it's more easy do it with octane's turntable
you have only to remember to set the vignetting to 0, fov 90, focal distance at minimum and only 4 frames for 360 degree. For top and bottom play with the camera upvector
ciao beppe
Re: yacht cabin
Posted: Fri Mar 23, 2012 10:39 pm
by gabrielefx
bepeg4d wrote:it's more easy do it with octane's turntable
ciao beppe
in Max a rig of 6 instanced cameras is much easier because you can animated it
Re: yacht cabin
Posted: Fri Mar 23, 2012 10:40 pm
by gabrielefx
KaroBastardKiter wrote:you can clearly see it's a cube tho. isn't there a way to achieve a better result?
you can convert it
Re: yacht cabin
Posted: Mon Mar 26, 2012 7:10 am
by 3rdeye
Excellent work mate !!
