I haven't tried it, but I think you could use an empty for your DOF, and parent (or track, hmmmm Needs clairfing :p )it with your Camera, then move or animate your DOF anywhere you like.
Cheers,
Tungerz
yoyoz wrote:@ SamCameron: I can't look at the frame problem now, but for the error you had please replace the util.py file with the one attached. It will not fix your problem but will add an extra log so we know which file is not found.
@ Radiant: I can't do anything without a description of the problem and some logs.
@ r0ug3r: I've posted a sample anim+blend one month ago about animating DoF: http://www.refractivesoftware.com/forum/viewtopic.php?p=43464#p43464
r0ug3r wrote:the only problem i had is the reloading of scene and reconnecting to octane. seems at every frame we have to reload everything and reconnect to octane (coz i tried to disconnect the wifi during rendering and octane doesnt continue...reconnecting on a loop)..
is there anyway we can do it that only one time we reload (voxilize)the scene at octane then continue animation. and only one time connecting to octane server.I think i read this issue somehow in the forum.
Aenima wrote:I want to ask some feature. Is any reason for batch saving all object with their position to separate obj files?
