What is the shortcut key for re-rendering? And how can I set this shortcut key in Cinema 4D? I have a large number of pictures to create and need the shortcut key to improve efficiency.
还有这里的帖子我如何添加图片,方便问你们问题
C4DOC
- TomasCremin
Shortcut Ctrl + R. To set the key, go to Edit => Customization => Customize Commands, type Render View in the search bar => Click the "Shortcut" box below the command list => Assign to save.
- thomasfrank32
1. Shortcuts to Re-render in Cinema 4D:
By default, to re-render the current frame in Cinema 4D, you use:
Shift + R (Render View/Active View)
Ctrl/Cmd + R: Quickly render the viewport
2. How to set up your shortcuts in Cinema 4D:
Go to the menu: Window → Customization → Customize Commands…Among Us Online
In the window that appears, type in the search box: Render
Find the command you want, such as "Render to Picture Viewer" or "Render View"
Below, select “Shortcut”, click Record Shortcut, then press the key combination you want to assign.
Click Assign → Save as Startup Layout (if you want to use it forever)
