Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby bepeg4d » Mon Oct 12, 2020 6:36 am
bepeg4d Mon Oct 12, 2020 6:36 am
Hi guys,
currently only Standalone PR2 demo is available.
To check if your Mac is already supported in Catalina, please upgrade to 10.15.7, then download and install Standalone OctaneX PR2 demo:
https://render.otoy.com/downloads/a/113 ... _macos.dmg
Then open Standalone demo, right click anywhere in the node graph panel, and choose Materials/Metallic, to create the material node.
Now right click on the node and choose Render:
If you have a similar result, you have a Vega or Navi GPU, and your Mac is already supported!
If not, and if you GPU is an AMD Polaris or Intel Skylake model, it will be supported by the upcoming Mac Os 11 Big Sur new Apple Metal driver, so you need to wait a little bit more.
OctaneX plugins demo versions are not available yet, but should be available with the next PR update.
At the moment, there are OctaneX plugins for C4D, Houdini, Maya, Poser, Unreal, Blender, Sketchup, Hydra Solaris, Lightwave, and Modo is on the go.
For new Otoy customers, if you cannot wait for the demo versions, and want to try also the plugins, you can buy a Studio subscription for € 19.99/month, and cancel it just after activation:
https://home.otoy.com/render/octane-ren ... ns/#studio
In this way it will not automatically renew at the end of the month, and you can try OctaneX for one month without restrictions.
Happy Mac GPU Rendering,
ciao Beppe
Crash on Quit
Postby keithrondinelli1974 » Wed Oct 14, 2020 2:06 pm
keithrondinelli1974 Wed Oct 14, 2020 2:06 pm
I'm running Cinema 4D S22.123 with Octane PR2 and am getting a crash on quit every time. Anyone else experiencing this?
Mac Pro 2019
Catalina 10.15.17
AMD Radeon Pro Vega II 32 GB
Radeon Pro W5700X
It's probably been noted, but I also get crashes when I solo a node in the Octane material node editor.
keithrondinelli1974
Postby kinedix » Wed Oct 14, 2020 5:26 pm
kinedix Wed Oct 14, 2020 5:26 pm
Hey everyone what am I doing wrong? Used this tutorial https://www.youtube.com/watch?v=7tTLH8wqMYQ
When ever I subdivide object it gets artifacts, no matter C4D native or inside Octane.
kinedix
Postby ckmaes_1 » Thu Oct 15, 2020 4:07 am
ckmaes_1 Thu Oct 15, 2020 4:07 am
Is there an update on when we can expect cross platform network rendering as shown in the GTC presentation for Octane X, so host being a Mac with Octane X and the render node being a Windows PC running 2020.x?
With PR3 being feature complete is this going to be included in the release this week or will it still follow the final release of Big Sur?
Sure would love to run Octane X inside Maya on my Mac with the heavy lifting (IPR / final render) being done on the PC with a couple of RTX 3080/90.
ckmaes_1
Postby bepeg4d » Thu Oct 15, 2020 6:17 am
bepeg4d Thu Oct 15, 2020 6:17 am
Hi kinedix,
are you using c4d shaders in your Octane materials?
If yes, you need to increase the baking resolution in c4doctane/SettingsC4D Shaders panel.
ciao Beppe
Postby juliangwan » Thu Oct 15, 2020 5:19 pm
juliangwan Thu Oct 15, 2020 5:19 pm
Is there still a way to join the closed beta whitelist for Big Sur? For the metal drivers I need?
I have an Apple Dev account, Mac Pro w/ AMD Radeon Pro W5700X 16 GB running Big Sur Version 11 Beta.
I really miss using my Octane in C4D :(
juliangwan
Postby Ahr0n » Thu Oct 15, 2020 7:09 pm
Ahr0n Thu Oct 15, 2020 7:09 pm
The PR3 is complete so the OTOY team knows all the details and compatibility possibilities. I can now ask about most crucial thing - will my Macs run Octane X?
I have two Macs:
- MBP 18 with Pro 555X - I assume that it is capable, coz it is a fairly new card.
- iMac late 2014 with R9 M290X - is there a chance to see X on it?
I don't have huge expectations for that last one in terms of speed, but I'd like to know if it's going to run the X. Also - are you going to release Octane X the same day Big Sur is released?
Ahr0n
Postby kinedix » Thu Oct 15, 2020 9:27 pm
kinedix Thu Oct 15, 2020 9:27 pm
Just double checked, that test was with standard material, and I replaced with Octane diffuse material, and exact the same result unfortunately, but thank you for suggestion.
Eduard
kinedix
Postby bepeg4d » Fri Oct 16, 2020 9:44 am
bepeg4d Fri Oct 16, 2020 9:44 am
@juliangwan: you can already use your Mac if you install Catalina 10.15.7, even on an external hdd/sdd. Since your GPU is a Navi model, you don’t need to wait for Big Sur.
@Ahr0n: your MBP 18 with Pro 555X will be supported in Big Sur, since 55X is a Polaris model.
Your iMac late 2014 with R9 M290X will not be supported, unless you add a supported GPU via Thunderbolt, but please consider that in OctaneX the AI Denoiser is performed via CPU, not GPU, and you should need a CPU from 2015 or newer for performing AI Denoiser with OctaneX.
Older CPUs do not have the necessary instructions for AI Denoiser.
@kinedix: please use Octane materials with Octane node only inside, when working with Baking Camera.
ciao Beppe
Postby Ahr0n » Fri Oct 16, 2020 11:17 am
Ahr0n Fri Oct 16, 2020 11:17 am
Thanks Beppe. Should I upgrade to Big Sur when it'll be released or I can stay on Catalina to use Octane X? There are some problems with eGPUs on Big Sur, hope Apple will fix them.
Ahr0n
PreviousNext
Return to Bug Reports
Tue Jan 26, 2021 6:02 am [ UTC ]
