The issue with PR1 support has been solved now!
ciao Beppe
Moderator: JimStar
jschoenith wrote:Thanks Beppe. Any update on when we can expect Octane X PR2 for C4D?
in OctaneX, AI Denoiser is performed by the CPU, not the GPU, so it is a bit slower to calculate, but it does not affect GPU memory, and does not need to select a GPU for it.
Note that you need a CPU from 2015 or newer, to have the necessary instructions to perform AI denoiser.
Stathis wrote:in OctaneX, AI Denoiser is performed by the CPU, not the GPU, so it is a bit slower to calculate, but it does not affect GPU memory, and does not need to select a GPU for it.
Is this going to change in the future so we can use GPU for denoise or is this some hardware limitation for AMD gpus?
aoktar wrote:jschoenith wrote:Thanks Beppe. Any update on when we can expect Octane X PR2 for C4D?
This week if we're lucky!
