Very large scene GPU/CUDA Error
Forums: Very large scene GPU/CUDA Error
Houdini Integrated Plugin
Postby davidyannick_1 » Thu May 28, 2020 10:31 am
davidyannick_1 Thu May 28, 2020 10:31 am
I have a big scane (terrain 17 000 000 polys) and 60 000 trees instances, when I try to render it in Redshift it's very fast but with Octane here is the result :
*** OCTANE API MSG: CUDA error 2 on device 0: out of memory
*** OCTANE API MSG: -> failed to allocate device memory
*** OCTANE API MSG: Out-of-core memory limit exceeded
My pc : I7 8700k - 64go RAM - 1080Ti with latest studio drivers
Any idea ?
Thx
davidyannick_1
Re: Very large scene GPU/CUDA Error
Postby juanjgon » Thu May 28, 2020 12:08 pm
juanjgon Thu May 28, 2020 12:08 pm
Have you tried to break the terrain objects into two objects? Octane has some limitations related to how many polygons can be stored in a single OBJ node, so perhaps this is the problem. If this doesn't help, you could try to enable the out of core feature to check if the problem is that the scene doesn't fit in the available GPU memory.
juanjgon
Postby davidyannick_1 » Thu May 28, 2020 12:41 pm
davidyannick_1 Thu May 28, 2020 12:41 pm
juanjgon wrote:Have you tried to break the terrain objects into two objects? Octane has some limitations related to how many polygons can be stored in a single OBJ node, so perhaps this is the problem. If this doesn't help, you could try to enable the out of core feature to check if the problem is that the scene doesn't fit in the available GPU memory.
ok gonna try do you what is the size limit per obj ?
thx
davidyannick_1
Postby juanjgon » Thu May 28, 2020 12:49 pm
juanjgon Thu May 28, 2020 12:49 pm
It depends on the number of attributes, like UV maps, and so on. It could be just around these 17 MPolygons, but it is hard to say.
juanjgon
Postby davidyannick_1 » Thu May 28, 2020 1:12 pm
davidyannick_1 Thu May 28, 2020 1:12 pm
juanjgon wrote:It depends on the number of attributes, like UV maps, and so on. It could be just around these 17 MPolygons, but it is hard to say.
ok thanks for the info :)
davidyannick_1
Return to Houdini
Users browsing this forum: No registered users and 18 guests
Wed Apr 24, 2024 11:03 pm [ UTC ]
