Sculptron 1.0 - Alpha Preview Release
Forums: Sculptron 1.0 - Alpha Preview Release
Discussion forum for Sculptron
Re: Sculptron 1.0 - Alpha Preview Release
Postby linograndiotoy » Fri Dec 13, 2019 10:10 am
linograndiotoy Fri Dec 13, 2019 10:10 am
amandas wrote:
linograndiotoy wrote:
amandas wrote:This is the default view (deleted imgui.ini). Also, I will help you with debbuging this: when I changed taskbar settings to Auto Hide in Desktop Mode, suddenly the main menu bar appeared. I am guessing here this might be aspect ratio related. When I quit app and restart, the main menu bar is missing again (it reappears when I change taskabar settings).
Can you please try to press the Windows key+Left Arrow (to snap selected window to the left or right half of the screen) and see if you can see the menu bar?
That does the trick. Snapping to any border makes the main menu bar reappear.
Best!
Good! Next build will store the UI configuration correctly, so this should be solved.
linograndiotoy
Postby ramone163 » Mon Dec 16, 2019 5:18 pm
ramone163 Mon Dec 16, 2019 5:18 pm
When the next build will be released?
PS. When saving the project and open it - parameters do not save.
GPU: 980+1080+1080Ti; 3ds max;
Behance portfolio; Handmadefont.com;
ramone163
Postby andrey.krivulya » Mon Dec 16, 2019 7:23 pm
andrey.krivulya Mon Dec 16, 2019 7:23 pm
Hi, dear developers =)
Is it possible in Sculptron?
https://vimeo.com/379550189
win 10 /64x Intel Core i9-11980HK - 64Gb RAM - 3080 Laptop - 16Gb VRAM - AERO 15 OLED YD
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
andrey.krivulya
Postby linograndiotoy » Tue Dec 17, 2019 12:53 am
linograndiotoy Tue Dec 17, 2019 12:53 am
andrey.krivulya wrote:Hi, dear developers =)
Not right now. For future releases we're thinking about something even better than that! ;)
linograndiotoy
Very soon!
linograndiotoy
Postby andrey.krivulya » Tue Dec 17, 2019 7:28 am
andrey.krivulya Tue Dec 17, 2019 7:28 am
Please add "Dynamic Triangulation" and 2x2080Ti with NVLink support =)
andrey.krivulya
Postby matrix2012 » Wed Jan 08, 2020 9:12 pm
matrix2012 Wed Jan 08, 2020 9:12 pm
Will there be a Linux version?
matrix2012
Postby Notiusweb » Mon Jan 13, 2020 3:53 am
Notiusweb Mon Jan 13, 2020 3:53 am
Does Sculptron have cameras for different views / pans over a timeline sequence
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Postby Alessandrobassp » Wed Jan 15, 2020 6:59 pm
Alessandrobassp Wed Jan 15, 2020 6:59 pm
Guys, it's not working... I've re-installed several times, or updated the cuda, but at 3d object display level it doesn't work well, at normal level and at shader display level... I don't really know what the problem is.
Please help me. I'm curious to try Sculptron.
Alessandrobassp
Postby linograndiotoy » Thu Jan 16, 2020 10:20 am
linograndiotoy Thu Jan 16, 2020 10:20 am
Hi Alessandro!
What about your system configuration? Which OS are you using? Which graphic card?
linograndiotoy
PreviousNext
Return to Sculptron
Users browsing this forum: No registered users and 15 guests
Thu Apr 25, 2024 8:42 pm [ UTC ]
