Sculptron 1.0 - Alpha Preview Release
Forums: Sculptron 1.0 - Alpha Preview Release
Discussion forum for Sculptron
Re: Sculptron 1.0 - Alpha Preview Release
Postby linograndiotoy » Wed Dec 11, 2019 9:49 am
linograndiotoy Wed Dec 11, 2019 9:49 am
amandas wrote:This is the default view (deleted imgui.ini). Also, I will help you with debbuging this: when I changed taskbar settings to Auto Hide in Desktop Mode, suddenly the main menu bar appeared. I am guessing here this might be aspect ratio related. When I quit app and restart, the main menu bar is missing again (it reappears when I change taskabar settings).
Can you please try to press the Windows key+Left Arrow (to snap selected window to the left or right half of the screen) and see if you can see the menu bar?
linograndiotoy
Postby linograndiotoy » Wed Dec 11, 2019 10:36 am
linograndiotoy Wed Dec 11, 2019 10:36 am
Notiusweb wrote: Can you import an Alembic animation?
(in place of a series of OBJs on the frame timeline)
Would want to convert the imported alembic animation to a volume ABC, and then exporting that to Octane!
Not yet. As specified in the main post, Alembic import/export will be implemented soon (is one of the highest priorities for Sculptron).
linograndiotoy
Postby Notiusweb » Wed Dec 11, 2019 1:54 pm
Notiusweb Wed Dec 11, 2019 1:54 pm
1) Oh, will it handle multiple ABCs in once scene? So that one VDB can interact with another via Sculptron.
2) How about FBXs with rigs and animation and blendshapes....to risky? :D
But my major question-
3) Could a Vectron be exported into Sculptron, so that it can be warped and animated, and then later be rendered in Octane...with Spectron? :P
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Postby Agendum » Wed Dec 11, 2019 6:36 pm
Agendum Wed Dec 11, 2019 6:36 pm
Importing models is very inconsistent from C4D in obj format (like a torus.)
Agendum
Postby linograndiotoy » Wed Dec 11, 2019 10:36 pm
linograndiotoy Wed Dec 11, 2019 10:36 pm
Agendum wrote:Importing models is very inconsistent from C4D in obj format (like a torus.)
In which way is it inconsistent?
linograndiotoy
Postby linograndiotoy » Wed Dec 11, 2019 10:40 pm
linograndiotoy Wed Dec 11, 2019 10:40 pm
Notiusweb wrote:1) Oh, will it handle multiple ABCs in once scene? So that one VDB can interact with another via Sculptron.
About Alembic, it will be possible to import as many Alembic files as needed.
FBX needs an animation and bone deformation system in place first, so is not among the highest priorities right now.
The current internal build can export SDF files, which can be used with Vectron (you can use booleans combining SDFs and Vectron items).
linograndiotoy
Postby Agendum » Thu Dec 12, 2019 12:05 am
Agendum Thu Dec 12, 2019 12:05 am
If I try to import a model converted from C4D to obj format, nothing shows. Ive imported another random asset which worked but not something like a quick primitive. Im not exactly sure.
Agendum
Postby jay3dlinux » Thu Dec 12, 2019 8:00 am
jay3dlinux Thu Dec 12, 2019 8:00 am
If you could provide the problematic obj file that would be of great help fixing this issue.
jay3dlinux
Postby linograndiotoy » Thu Dec 12, 2019 9:58 am
linograndiotoy Thu Dec 12, 2019 9:58 am
Cinema exports some huge sized OBJs. I think the obj gets loaded fine in Sculptron, but is off the camera clip limits. You can change the Imported OBJ Scale factor to 0.1 in the Sculptron Option menu to solve the issue.
linograndiotoy
Postby amandas » Thu Dec 12, 2019 12:40 pm
amandas Thu Dec 12, 2019 12:40 pm
That does the trick. Snapping to any border makes the main menu bar reappear.
Best!
amandas
PreviousNext
Return to Sculptron
Users browsing this forum: No registered users and 16 guests
Fri Apr 19, 2024 5:49 pm [ UTC ]
