Sculptron 1.0 - Alpha Preview Release
Forums: Sculptron 1.0 - Alpha Preview Release
Forum for discussing Redspec SSS.
Moderator: TRRazor
RedSpec SSS and TGX © RedSpec SSS
http://redspec-sss.com
Re: Sculptron 1.0 - Alpha Preview Release
Postby linograndiotoy » Fri Dec 06, 2019 5:58 pm
linograndiotoy Fri Dec 06, 2019 5:58 pm
pegot wrote:What does the parameter for samples control (default is set to 256)?
Samples only affects the volumetric visualization in OpenGL.
linograndiotoy
Postby chikegar » Sat Dec 07, 2019 2:36 pm
chikegar Sat Dec 07, 2019 2:36 pm
This reminds me so much of Chronosculpt that came out six years ago from the makers of Lightwave. :) I know you're very familiar with it Lino Grande. ;) Unfortunately, the programmer who wrote the program is no longer with the Lightwave team, so Chronosculpt has not been updated in years.
https://youtu.be/oJdnmL3u8fE
Cheers,
Gary Chike
chikegar
Postby linograndiotoy » Mon Dec 09, 2019 10:20 am
linograndiotoy Mon Dec 09, 2019 10:20 am
chikegar wrote:This reminds me so much of Chronosculpt that came out six years ago from the makers of Lightwave. :) I know you're very familiar with it Lino Grande. ;) Unfortunately, the programmer who wrote the program is no longer with the Lightwave team, so Chronosculpt has not been updated in years.
Cheers,
Gary Chike
Yes, I'm more than familiar with ChronoSculpt Gary! David Ikeda developed the software (with the help of other coders), and it was used in several important productions (the most recent being Love Death + Robots on Netflix).
Sculptron today already offers well more than ChronoSculpt can do and its evolution will show we're dealing with something very different, more powerful and covering a wider range of production situations.
linograndiotoy
Postby amandas » Mon Dec 09, 2019 11:24 am
amandas Mon Dec 09, 2019 11:24 am
This looks fabulous!
Unfortunately, I seem to have UI issues. I do not see the top bar, and only 3 windows are present (Animation Editor, Items, Tools). is this because:
a) you limited the alpha version functionality?
b) you are using ImGUI docking branch, which is still experimental (I am developing a 3D app myself, and immediately recognized the UI)?
Best regards
amandas
Postby linograndiotoy » Tue Dec 10, 2019 10:29 am
linograndiotoy Tue Dec 10, 2019 10:29 am
amandas wrote:This looks fabulous!
Best regards
Hi!
The alpha version of Sculptron is not limited in any way.
Yes, that's what we're using. It's experimental but quite stable and usable. The missing windows can be opened from the menu bar (which you can't see for some reason). Can you please show me a screenshot of what you see when you open Sculptron?
linograndiotoy
Postby amandas » Tue Dec 10, 2019 3:47 pm
amandas Tue Dec 10, 2019 3:47 pm
Best regards
Hi!
screen attached.
This is the default view (deleted imgui.ini). Also, I will help you with debbuging this: when I changed taskbar settings to Auto Hide in Desktop Mode, suddenly the main menu bar appeared. I am guessing here this might be aspect ratio related. When I quit app and restart, the main menu bar is missing again (it reappears when I change taskabar settings).
Best!
amandas
Postby linograndiotoy » Tue Dec 10, 2019 5:16 pm
linograndiotoy Tue Dec 10, 2019 5:16 pm
A sneek peak of the next Sculptron Build:
linograndiotoy
Postby Notiusweb » Tue Dec 10, 2019 6:42 pm
Notiusweb Tue Dec 10, 2019 6:42 pm
Can someone explain what this program does-
I look at the thread and I get lost in the words going back and forth, so I just look at the pictures.
Sometimes I see a bust of a robot, and then other times a volume mesh....
What is the program doing!?.... :oops:
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Notiusweb
Postby linograndiotoy » Tue Dec 10, 2019 6:51 pm
linograndiotoy Tue Dec 10, 2019 6:51 pm
Notiusweb wrote:Can someone explain what this program does-
The very first post of this thread should help. Did you see the videos?
https://youtu.be/aEcKpEvTVcc
If you have any specific question, I'll be happy to answer.
linograndiotoy
Postby Notiusweb » Wed Dec 11, 2019 3:27 am
Notiusweb Wed Dec 11, 2019 3:27 am
Can you import an Alembic animation?
(in place of a series of OBJs on the frame timeline)
Would want to convert the imported alembic animation to a volume ABC, and then exporting that to Octane!
Plugs: Enterprise
Notiusweb
PreviousNext
Return to Redspec SSS
Thu Jan 28, 2021 5:48 am [ UTC ]
