Updated texture image ignored by vertex displacement node
Forums: Updated texture image ignored by vertex displacement node
Postby scooternva » Fri Nov 29, 2019 7:06 pm
scooternva Fri Nov 29, 2019 7:06 pm
I have an Octane Texture Image node that is using spherical projection via an Octane Projection node attached to the Projection pin. The image node is connected to the Texture pin of an Octane Vertex Displacement node, which is displacing a tessellated sphere 100 meters in diameter.
If I update the image file that's driving the displacement, I'm not seeing the updated results in the Octane IPR preview window. I've tried:
  1. clicking the "Reload" button in the IPR window
  2. changing the image in the image node to something else and then changing it back
  3. forcing the image to reload in LightWave (F6)
  4. closing and reopening the IPR window
The only thing that seems to work is completely reloading the entire scene in Layout. This is not very conducive to iterative testing. Is this a LightWave bug or an issue in OctaneRender?
Thanks...
Octane 2020.2.3.1 | LightWave 2019.1.5 (3134) | Win10 Pro 19041.1052 | 2 x Gigabyte AORUS RTX 2080 Ti Xtreme w/NVLink | Gigabyte AORUS Xtreme X399 | AMD Ryzen 2950X | 64 GB RAM | SSDs: Samsung 970 PRO 512 GB + Seagate FireCuda 510 2 TB | blog.gammans.zone
scooternva
Re: Updated texture image ignored by vertex displacement node
Postby juanjgon » Tue Dec 03, 2019 6:19 pm
juanjgon Tue Dec 03, 2019 6:19 pm
I'm sorry, but I can't reproduce anything like that here. Can you share your scene and textures to take a look at it here?
juanjgon
Postby scooternva » Tue Dec 03, 2019 8:42 pm
scooternva Tue Dec 03, 2019 8:42 pm
Well of course now I can't reproduce the issue with a test image, and I am not keen on sharing my actual production image files (plus I'm done with that model so I'm not even working on that one anymore). I'll be doing something else with displacement in a few weeks so if I'm able to replicate the problem I'll update this thread. Thanks!
scooternva
Return to Lightwave 3D
Fri Mar 29, 2024 11:04 am [ UTC ]
