Gradient problem
Forums: Gradient problem
Houdini Integrated Plugin
Gradient problem
Postby shishkovdima » Mon Dec 02, 2019 4:29 pm
shishkovdima Mon Dec 02, 2019 4:29 pm
Hello,
I am using Houdini 17.5.391 on Windows 7 and Octane 2019.1.2.
I am unable to control the contrast of an image or procedural noise using Octane's gradient node. I can change the colors though, but moving gradient points does nothing at all.
Here is the videoshowing the problem: https://www.dropbox.com/s/z8f9bivx50acn ... m.mp4?dl=0
Is it a bug or am I doing anything wrong?
shishkovdima
Re: Gradient problem
Postby juanjgon » Mon Dec 02, 2019 9:50 pm
juanjgon Mon Dec 02, 2019 9:50 pm
There is a known limitation that can be related to this behavior. The problem is that the Octane gradient node always must have keys at the start and end points. You can add additional keys to control de gradient, but it must have the first and last keys always in the extreme positions, at 0.0 and 1.0.
I'll try to fix this limitation in one of the upcoming builds.
juanjgon
Postby shishkovdima » Mon Dec 02, 2019 10:10 pm
shishkovdima Mon Dec 02, 2019 10:10 pm
juanjgon wrote:There is a known limitation that can be related to this behavior. The problem is that the Octane gradient node always must have keys at the start and end points. You can add additional keys to control de gradient, but it must have the first and last keys always in the extreme positions, at 0.0 and 1.0.
Thank you very much for the fast reply. Got it working by adding additional gradient points.
Best wishes,
Dima
shishkovdima
Postby juanjgon » Mon Feb 03, 2020 2:30 pm
juanjgon Mon Feb 03, 2020 2:30 pm
This limitation will be fixed in the next Octane 2020.1 plugin build.
juanjgon
Return to Houdini
Users browsing this forum: No registered users and 7 guests
Fri Apr 19, 2024 10:37 pm [ UTC ]
