Hello enricocerica!
on the screenshot i noticed misprint button "E_port OBJ/MTL only"
Haven't tried the script yet - awaiting my authorization number for octane
bepea wrote:Hi!
First off all THANK YOU!! for this superb plugin! No more 2.49!! Im just so happy
The secound thing is im getting this error when im exporting using a already existing .ocs file.
The error occurs independent of what I save in octane, so any change in the default export settings and saving them to a .ocs file causes the error.
SnoWWolf wrote:Hello enricocerica!
enricocerica wrote:Not sure this has to do with the script
Could you check if the ocs file has been created with the same Octane version?
the_nautilus wrote:Thanks much enricocerica! Been waiting for this anxiously.
I had some issues getting the script running at first but then figured out what I was doing wrong and thought I would post to help anyone else having this issue. The main issue was that when I hit the render button in a default scene, the button would hi-light but it wouldn't launch the Octane executable. However after some tinkering, I learned that there needs to be a 'Sun' lamp in the scene and then it will launch just fine. Hope that helps!
Users browsing this forum: Bing [Bot], Fredrikvictorhugo and 13 guests
