Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
Forums: Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
Moderator: aoktar
Re: Cinema 4D version 4.05 (Latest stable) 12.08.2019
Postby VVG » Tue Aug 13, 2019 7:26 am
VVG Tue Aug 13, 2019 7:26 am
cutoff (from 2019) not working?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
Postby aoktar » Tue Aug 13, 2019 9:30 am
aoktar Tue Aug 13, 2019 9:30 am
VVG wrote:cutoff (from 2019) not working?
Appearently I missed to remove it while making 4.05 build. I'll remove on next build.
Postby stefano-dear » Tue Aug 13, 2019 12:35 pm
stefano-dear Tue Aug 13, 2019 12:35 pm
Rounded edges are no more available?
stefano-dear
Postby aoktar » Tue Aug 13, 2019 7:39 pm
aoktar Tue Aug 13, 2019 7:39 pm
thanulee wrote:
aoktar wrote:
thanulee wrote:Heya, W coordinate doesnt work with bump channel ?
I render c4d hair via an octane tag and from there i try use W coordinate node for bump. It works in any other channel but bump. Was that always the case? thanks
Could you please share a sample scene?
here is is: https://www.dropbox.com/s/tqwciqszjbf6c ... p.c4d?dl=0
ty
Yes it is not working. It seems like a renderer problem. We'll check it
Re: Cinema 4D version 4.05 (Latest stable) 14.08.2019
Postby aoktar » Tue Aug 13, 2019 9:32 pm
aoktar Tue Aug 13, 2019 9:32 pm
Fixed roundEdges parameter and removed cutoff and updated archives. Sorry for mistakes!
Postby divasoft » Wed Aug 14, 2019 6:28 am
divasoft Wed Aug 14, 2019 6:28 am
Hi Aoktar. In fullscreen mode i can't drag LV window. First time this window had controls like "close", "minimise window", but then they disappeared.
What can i do to drag LV?
divasoft
Postby aoktar » Wed Aug 14, 2019 9:10 am
aoktar Wed Aug 14, 2019 9:10 am
divasoft wrote:Hi Aoktar. In fullscreen mode i can't drag LV window. First time this window had controls like "close", "minimise window", but then they disappeared.
Why do you want to drag it? It's fullscreen mode that for seeing just render output. So don't have any gui elements. Just use ctrl+Tab to maximize
Postby sdanaher » Wed Aug 14, 2019 9:41 am
sdanaher Wed Aug 14, 2019 9:41 am
As per 2019.1 RC2 comment below, Normalise lights switch is broken in 4.05 too. Its a rather urgent problem as scenes from 4.04 that use light temps will no longer match. (unless this feature has been disabled on purpose, though I can't imagine why?)
very easy to test for yourself - add two lights, make one 9000k the other 2000k, normalise switch on the red one does nothing, it'll remain much dimmer.
https://render.otoy.com/forum/viewtopic.php?f=85&t=72158&p=366295#p366295
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher
Postby bepeg4d » Wed Aug 14, 2019 10:28 am
bepeg4d Wed Aug 14, 2019 10:28 am
Hi sdanaher,
sorry but I’m not able to reproduce the issue you described, in both v4.05, and v2019.1-RC3:
Do you mind to share an example scene?
ciao Beppe
Postby sdanaher » Wed Aug 14, 2019 12:13 pm
sdanaher Wed Aug 14, 2019 12:13 pm
bepeg4d wrote:Hi sdanaher,
ciao Beppe
Hey Beppe. Can you try by using a scene which was first created in 4.04? I have a 'new.c4d' template scene created in 4.04 which contains lights and other stuff. These lights have the issue, as do scenes that were created in 4.04. EDIT... seems to happen if I create new lights in 4.05 too.
sdanaher
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 8 guests
Thu Apr 25, 2024 1:20 am [ UTC ]
