How can I set PBR Unity Light Component properties by script
Forums: How can I set PBR Unity Light Component properties by script
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby neitron » Fri Jul 19, 2019 4:02 pm
neitron Fri Jul 19, 2019 4:02 pm
Hi!
I want to set a few properties for Octane Light via PBR Unity Light Component by c# script, just before rendering the final image by Octane renderer.
The options:
// Octane light options available via the editor
Blackbody type
Power for the light
Temperature for the light
IES file for light distribution
// IES options are able to set from Octane but not by the PBR component in the editor. Please provide it through unity component
The 'Gama' for the IES file node
The 'Power' For the IES file node
The 'Projection' for the IES file node
In future, I wish to edit other options as well.
Is there any way to set it without reflection?
neitron
Re: Whow can I set PBR Unity Light Component properties by scrip
Postby jakemetz » Fri Jul 19, 2019 9:13 pm
jakemetz Fri Jul 19, 2019 9:13 pm
+1 to this. The ability to use IES files from the Unity Editor to Octane would be a great boost to our pipeline!
jakemetz
Re: How can I set PBR Unity Light Component properties by script
Postby ChrisHekman » Tue Jul 23, 2019 3:52 pm
ChrisHekman Tue Jul 23, 2019 3:52 pm
We have made PBR Unity Light Components public in the upcomming build. Which will allow you to access Octane.UnityLight and and OctaneUnity.PBRUnityLightComponent.
You should be able to retrieve the emissive node and the ies light node from C#.
ChrisHekman
Postby neitron » Wed Jul 24, 2019 10:25 am
neitron Wed Jul 24, 2019 10:25 am
Thank you very much for that!
But how about the projection node?
Could you please provide some examples of how to retrieve exact nodes?
Or maybe there is one tiny example that shows how to edit at least one property of unity light (temperature for example).
neitron
Postby jakemetz » Wed Jul 24, 2019 7:55 pm
jakemetz Wed Jul 24, 2019 7:55 pm
That's great news! Thanks for including that Chris. Much appreciated.
Out of curiosity (so that we can plan), do you have an estimate for when the upcoming build might be released?
jakemetz
Postby neitron » Fri Jul 26, 2019 4:05 pm
neitron Fri Jul 26, 2019 4:05 pm
neitron wrote:Thank you very much for that!
Please unswerv to this one
neitron
Postby ChrisHekman » Tue Jul 30, 2019 3:35 pm
ChrisHekman Tue Jul 30, 2019 3:35 pm
In the upcomming build you should be able to do something like this:
Gameobject targetgameobject; //Your game object
var pbrLight =  targetgameobject.GetComponent<PBRUnityLightComponent>();
Octane.UnityLight OctaneLight = pbrLight.OctaneLight;
Octane.Node MaterialNode = OctaneLight.GetMaterial();
Octane.Node EmissionNode = MaterialNode.GetConnectedNode(Octane.P_EMISSION);
EmissionNode.SetPinFloat(Octane.P_POWER, 400);
ChrisHekman
Postby mathaig » Wed Jul 31, 2019 6:52 am
mathaig Wed Jul 31, 2019 6:52 am
Hello, could we have an approximate date for the upcoming release ?
mathaig
Return to Octane for Unity
Users browsing this forum: No registered users and 7 guests
Fri Apr 19, 2024 2:44 am [ UTC ]
