HOW to Install? ( LW User)
Forums: HOW to Install? ( LW User)
Houdini Integrated Plugin
Re: HOW to Install? ( LW User)
Postby juanjgon » Thu Jun 13, 2019 10:13 pm
juanjgon Thu Jun 13, 2019 10:13 pm
The main problem can be that all the paths should be declared in the same variable, at least for the HOUDINI_PATH variable, so you could try something like that:
HOUDINI_DSO_ERROR = 2
MOPS = "C:/Users/X99 STRIX/Documents/MOPS;&"
PATH = "$APPDATA\SideFX\GameDevToolset\17.5\1.172\bin;C:\Otoy\Octane_2018.1.3.0_Houdini_17.5.258_Win64\bin;$PATH"
HOUDINI_PATH = "$MOPS;$APPDATA\SideFX\GameDevToolset\17.5\1.172;C:\Otoy\Octane_2018.1.3.0_Houdini_17.5.258_Win64;&"
juanjgon
Postby Paulbrownv » Thu Jun 13, 2019 10:20 pm
Paulbrownv Thu Jun 13, 2019 10:20 pm
Thank you Juanjo!
You did it! I had no idea that all paths should be declared in the same variable.
Cheers,
Paulbrownv
Postby mguisado » Tue Jul 30, 2019 10:26 am
mguisado Tue Jul 30, 2019 10:26 am
Hi Juanjo,
Also having an installing issue here.
I suspect the path of my .env is correct, since I see an octane shelf in Houdini.
The issue might be with versions. I just installed Houdini 17.5.327
This is the octane plugin I got installed
https://render.otoy.com/customerdownloa ... n64_vr.zip
I get this message when opening Houdini
Thanks in advance for your help.
mguisado
Postby juanjgon » Tue Jul 30, 2019 10:34 am
juanjgon Tue Jul 30, 2019 10:34 am
What is your houdini.env file?
juanjgon
Postby mguisado » Tue Jul 30, 2019 10:59 am
mguisado Tue Jul 30, 2019 10:59 am
Thanks for your quick response.
Please look below:
PATH = "C:/Users/MyUser/Documents/Houdini_17.5/bin;$PATH"
HOUDINI_PATH = "C:/Users/MyUser/Documents/Houdini_17.5;&"
mguisado
Postby juanjgon » Tue Jul 30, 2019 11:08 am
juanjgon Tue Jul 30, 2019 11:08 am
Hmm, but what plugin build are you trying to use with this latest Houdini production build? Inside the .zip file, there are plugin builds for several Houdini versions. You should try to use the plugin build for the latest Houdini version available, but if it doesn't work, I'm afraid that you are going to need to install the proper Houdini version for it.
juanjgon
Postby mguisado » Tue Jul 30, 2019 11:16 am
mguisado Tue Jul 30, 2019 11:16 am
Oh, I see.
I installed the 17.5.229 plugin and I'm running Houdini 17.5.327
Thanks for your help.
mguisado
Postby AlexSudnikov » Sun Feb 09, 2020 9:28 am
AlexSudnikov Sun Feb 09, 2020 9:28 am
Got the same issue...Using H18.287 , tried both 2019 and 2020 versions...still no luck.
AlexSudnikov
Previous
Return to Houdini
Users browsing this forum: No registered users and 17 guests
Sat Apr 20, 2024 1:16 am [ UTC ]
