Cinema 4D version 2019.1-XB2-Test1 (Experimental test ver.)
Forums: Cinema 4D version 2019.1-XB2-Test1 (Experimental test ver.)
Moderator: aoktar
Re: Cinema 4D version 2019.1-XB2-Test1 (Experimental test ver.)
Postby Iceman9 » Mon Jul 08, 2019 5:51 pm
Iceman9 Mon Jul 08, 2019 5:51 pm
aoktar wrote:
Iceman9 wrote:I understand that OSL can create so many possibilities that it is impossible to debug for everything. But I suggest that the sliders be clamped within sensible ranges, making it less easy to enter an absurdly high or low number.
slider ranges can be given in osl scripts. Are you talking about presets with ranges?
I understand there will be many OSL options that don't work in Octane core...and many times where there will be unpredictable results because of the huge possibility space. So maybe what I want is impossible.
But currently there are some sliders where moving it a little to the right or left will change the values by thousands or even millions , even where useful values might only be 1-10.
Also sometimes it seems the OSL values suddenly stop feeding into the displacement. For no reason the user can see. It will all appear good, then the displacement disappears.
Iceman9
Postby aoktar » Mon Jul 08, 2019 6:01 pm
aoktar Mon Jul 08, 2019 6:01 pm
Iceman9 wrote:But currently there are some sliders where moving it a little to the right or left will change the values by thousands or even millions , even where useful values might only be 1-10.
You can limit the values in scripts. for example here limited between 0-0.1
float thick=0.02[[float min=0, float max=0.1]]
Postby Iceman9 » Mon Jul 08, 2019 6:06 pm
Iceman9 Mon Jul 08, 2019 6:06 pm
Color inputs or previews are buggy.
Iceman9
Postby Iceman9 » Mon Jul 08, 2019 6:07 pm
Iceman9 Mon Jul 08, 2019 6:07 pm
aoktar wrote:You can limit the values in scripts. for example here limited between 0-0.1
Thnx
Iceman9
Postby aoktar » Mon Jul 08, 2019 6:16 pm
aoktar Mon Jul 08, 2019 6:16 pm
Iceman9 wrote:Color inputs or previews are buggy.
Yes previews are buggy from CORE. Next SDK will be ok.
Postby Iceman9 » Mon Jul 08, 2019 6:33 pm
Iceman9 Mon Jul 08, 2019 6:33 pm
The problem in selecting a color I think is limited to when using the color chip (HSV). Using the RGB sliders seem OK.
Iceman9
Postby aoktar » Mon Jul 08, 2019 11:25 pm
aoktar Mon Jul 08, 2019 11:25 pm
eyeonestudio wrote:Thank you. Ahmet~~
R19, R20 Working. :)
R21(latest version) Not working.
Nothing happens. I can not see the Octane menu and there is no error message on the console.
Win10 1809, Nvidia Driver 430.86, Titan Xp
It was an overlook about version controlling procedure. I've fixed the distribution files. Please re-download and install.
Postby Kalua » Tue Jul 09, 2019 6:35 am
Kalua Tue Jul 09, 2019 6:35 am
Seems like Sheen parameter is not working/having effect in shaders. R20
Cheers,
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby nejck » Tue Jul 09, 2019 9:21 am
nejck Tue Jul 09, 2019 9:21 am
Still doesn't work on my end :\
nejck
Postby aoktar » Tue Jul 09, 2019 10:47 am
aoktar Tue Jul 09, 2019 10:47 am
nejck wrote:Still doesn't work on my end :\
What's version number? Checked latest package, it's working on me.
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 17 guests
Thu Apr 25, 2024 9:11 pm [ UTC ]
