Underwater caustics
Forums: Underwater caustics
Underwater caustics
Postby Whispermode » Wed Mar 13, 2019 5:38 pm
Whispermode Wed Mar 13, 2019 5:38 pm
Do any of you good people know how I might create an underwater caustics effect in OB?
I found something specific to C4D the other day that shows a caustics option within Octane Light settings. Is there an equivalent method?
Whispermode
Re: Underwater caustics
Postby linograndiotoy » Wed Mar 13, 2019 10:20 pm
linograndiotoy Wed Mar 13, 2019 10:20 pm
Hi!
Could you please post the link to the Cinema 4D example?
Thanks.
linograndiotoy
Postby Whispermode » Wed Mar 13, 2019 11:21 pm
Whispermode Wed Mar 13, 2019 11:21 pm
linograndiotoy wrote:Hi!
Thanks.
Hi Lino,
https://youtu.be/oFWdNHmcmIY
Just realised it's in Physical, not Octane :oops:
...but the question still stands :D
Whispermode
Postby Whispermode » Thu Mar 14, 2019 9:35 am
Whispermode Thu Mar 14, 2019 9:35 am
Found some good pointers here from from bepeg4d and FAZ:
https://render.otoy.com/forum/viewtopic.php?f=30&t=63407&p=323785&hilit=caustics#p324459
...but it's a little disjointed i.e. I can't find 'specular depth' in the PT kernel.
I've had the most success with PMC kernel in terms of noise, but wonder if there's a more efficient way. 5K samples plus Denoiser rules animation out for me...
Whispermode
Postby frankmci » Thu Mar 14, 2019 4:37 pm
frankmci Thu Mar 14, 2019 4:37 pm
Also, depending on what you're doing, it's still usually a lot faster and easier to fake it with a gobo.
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby J.C » Thu Mar 14, 2019 9:43 pm
J.C Thu Mar 14, 2019 9:43 pm
Whispermode wrote:Do any of you good people know how I might create an underwater caustics effect in OB?
Could be doable with PMC kernel but render times will be very long. Better fake it as frankmci said.
System – Windows 11
J.C
Postby Whispermode » Thu Mar 14, 2019 10:34 pm
Whispermode Thu Mar 14, 2019 10:34 pm
frankmci wrote:Also, depending on what you're doing, it's still usually a lot faster and easier to fake it with a gobo.
Thanks, frankmci - I'm only just learning about gobos.
So how would you approach it in an animation? An image sequence of an underwater caustic pattern?
Whispermode
Postby frankmci » Fri Mar 15, 2019 4:23 pm
frankmci Fri Mar 15, 2019 4:23 pm
Yes, I'd probably use an image sequence. You can do it with an animated shader in Octane, but for me that tends to be very finicky, when I can knock out a sequence in After Effects in a few minutes. A sequence will also render faster, since Octane doesn't have to covert the shader to a bitmap for every frame each time.
The gobo rout will give you both caustics and nice god-rays without a lot of tweaking, and can render pretty fast without a crazy number of samples.
frankmci
Postby Whispermode » Fri Mar 15, 2019 5:16 pm
Whispermode Fri Mar 15, 2019 5:16 pm
OK, I'm going to give this a try. I really appreciate your help - thanks.
Whispermode
Postby linograndiotoy » Tue Mar 19, 2019 8:53 am
linograndiotoy Tue Mar 19, 2019 8:53 am
I would totally use an animated Octane Procedural texture to simulate this.
I included the scene i made. Turn on the preview and hit play.
You can use this as a mask so you can add animated caustics where needed.
I hope this helps.
Procedural_Caustics.blend
(541.09 KiB) Downloaded 327 times
linograndiotoy
Next
Return to Blender
Users browsing this forum: No registered users and 19 guests
Thu Apr 25, 2024 1:59 pm [ UTC ]
