Cinema 4D version 4.02.1-R3 (Obsolete stable)
Forums: Cinema 4D version 4.02.1-R3 (Obsolete stable)
Moderator: aoktar
Postby aoktar » Sat Feb 09, 2019 9:53 am
aoktar Sat Feb 09, 2019 9:53 am
Hi All,
This is the latest stable release of the plugin which is based on V4.02.1 SDK and matches OctaneRender Standalone 4.02.1. To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
Go to https://home.otoy.com/render/octane-render/purchase/
Select "Upgrade" in the top menu.
Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
2- Check gpu frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use same value. Also try to optimise your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for
investigating and bring a fix or solution.
Thanks for helping the development by your feedbackst! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Changes of V4.02.1-R3
- Fix: brdf type in octane materials come from old scenes.
- Fix: Missing parts for saved blend material in livedb.
- Fix: Render pause with denoising passes if you don't select denoiser in active camera which have enabled Imager.
Changes of V4.02.1-R2
- Single file saving for render layers with Octane-EXR file type by using exr compressions. Added half-float support
- Added full support for relative path names in renderpasses
- Fix: search function of livedb manager
- Fix: Brdf change issue with V1/V2 materials on V4. viewtopic.php?f=85&t=70622#p356762
Changes of V4.02.1
- Better log outputs
- Missing light render passes(directs/indirects)
- Bugfix: crash on exportORBX command if you don't have LiveViewer on startup layout
- commandline/nogui support on -exportORBX commandline parameter
- UDIM(Image Tiles texture) support
- Missing DeMain pass in Octane-EXR option
- Extended connection api for 3rd parties
- Fix: Wrong parameter list in Imagetexture -> "texture import type". It's fixed for some cases.
- Several minor fixes in plugin and core side(See standalone topic)
Changes of V4.01.1-R1
- Better display performance in LiveViewer
- Fix: Only displaying the vram stats for gpu0
- Minor speed improvement on scene preparation in animation rendering
- Fix: Show in Picture Viewer command
- Fix: Missing clones order in Scatter object with CSV mode
- Fix: Missing default value in Triplanar's coordinate space
Changes of V4.01.1
Fix: Texture tangent and some info passes in render settings
- Planetary environment.
- Orbx proxy object. Video: https://vimeo.com/302046063
- Fix: Unrecognized channel names in vdb file. viewtopic.php?f=30&t=69481#p350342
- No need to activate denoiser from SettingsWindow or cameraImager for getting denoising passes working in Picture Viewer
- Fix: Missing network render option for Studio builds.
- Fix: Wrong swap for objects/lights in Picture Viewer rendering when you have visibility animations.
- Fix: Extra beauty/denoising passes with RenderLayerMasks. viewtopic.php?f=86&t=68995
- Minor fixes over 4.00
Standalone
viewtopic.php?f=24&t=70612
WINDOWS REGULAR BUILD (R16-R20)
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R16-R20)
OSX REGULAR BUILD (R15-R20)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R20)
Requirements:
-You'll need to update your Cinema 4D to latest versions(min. R16.050, R17.053, R18.057, R19.053, R20.028)
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers at least 388.xx, recommended 417.22 or 419.17 (one of most recent with Cuda 9.1) and be carreful with latest drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
resource file for R15. Extract and replace old "c4doctane/res" directory with this.
res.rar
(7.23 MiB) Downloaded 336 times
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
ORBX EXAMPLE VIDEO
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
Re: Cinema 4D version 4.02.1(Latest stable) 09.02.2019
Postby Kalua » Sat Feb 09, 2019 4:34 pm
Kalua Sat Feb 09, 2019 4:34 pm
Thank you, Aoktar, for the release.
There is a Vectron buttom in the bottom of the "objects" tab in the live viewer window. I tried to use it and it just freezed C4D: I assume is a mistake to have this option in this version right?
Another small thing: V1 and 2 shaders versions migrated to V4 won't have WARD, GGX or Beckmann BRDF models recognized.
Other than that it seem s to work just fine. Image texture node in shader preview is so far working fine.
Cheers!
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby TonyBoy » Sat Feb 09, 2019 6:39 pm
TonyBoy Sat Feb 09, 2019 6:39 pm
Hi Ahmet,
to be clear there id no longer any support for C4D 15? Sticking to 4.01.1 will still give some good renders. It's been a good ride, thanks!
Regards,
Tony
TonyBoy
Postby mrpinoux » Sat Feb 09, 2019 7:40 pm
mrpinoux Sat Feb 09, 2019 7:40 pm
double - x 2 - to remove
Win 8.1 64 | Geforce GTX780 x 4 | i7 5960X | 64GB
mrpinoux
Postby aoktar » Sat Feb 09, 2019 10:15 pm
aoktar Sat Feb 09, 2019 10:15 pm
TonyBoy wrote:Hi Ahmet,
Regards,
Tony
I notified R15 has crash at start and didn't want to hold version for that. I don't have any idea what causes that. I'll try to find and make a build.
Postby aoktar » Sat Feb 09, 2019 10:19 pm
aoktar Sat Feb 09, 2019 10:19 pm
Kalua wrote:Thank you, Aoktar, for the release.
Cheers!
Sorry for that! I had a little time to build and got some problems to fix. I'll make a fix.
Postby thanulee » Sat Feb 09, 2019 11:20 pm
thanulee Sat Feb 09, 2019 11:20 pm
Thanks alot mate!!
thanulee
Postby aoktar » Sun Feb 10, 2019 12:09 am
aoktar Sun Feb 10, 2019 12:09 am
thanulee wrote:Thanks alot mate!!
Enjoy it! Regards!
Postby aoktar » Sun Feb 10, 2019 10:00 am
aoktar Sun Feb 10, 2019 10:00 am
Kalua wrote:Another small thing: V1 and 2 shaders versions migrated to V4 won't have WARD, GGX or Beckmann BRDF models recognized.
There was no any of these models in V2/V1
Postby sbstnc » Sun Feb 10, 2019 1:33 pm
sbstnc Sun Feb 10, 2019 1:33 pm
Behaviour is the same as 4.01 versions, C4D interface can't be used when LV is on.
Mac OSX 10.12.6, CUDA 387.178, GPU 378.05.05.25f01
2 x 1080Ti, C4D R20
Any scene with a decent amount of geo and textures, say 4-gb VRAM.
It's like C4D stops while LV updates. As soon as LV refreshes with new samples, C4D becomes responsive for a split second, before stopping again while LV thinks some more.
What's going on please. This has only happened since 4 on a machine where nothing else has changed for 18 months. Updating 10.12.6 from 10.12.4 and new drivers has not worked. I have work to get out and I can't press a damn button.
LV on prevents any sort of viewport navigation. Can't pan, can't move around, because C4D is only responsive for 0.01 seconds every 3 seconds. Pause the LV (if you can manage to press the pause button in that 0.1second) then magically the viewport becomes super fluid and response, can pan all over, tons of geo, no problems. LV back on... can't click anything, C4D too slow, LV just keeps trying to refresh refresh, it's like LV is sucking up all system resources, but looking at stats, on an 8core C4D is 100% of 1 core and memory is fine.
I'm pretty frustrated now.
Edit: looks like some max users posting the same thing, RC7 OK but 4 onward no good.
viewtopic.php?f=80&t=70062&p=355577#p355577
viewtopic.php?f=81&t=70257&p=355087&hilit=+lv+refresh+time+#p355087
Is it core that's the problem? If so why?
sbstnc
Next
Return to Releases
Fri Apr 19, 2024 11:30 pm [ UTC ]
