GPU efficiency and
Forums: GPU efficiency and
Re: GPU efficiency and
Postby J.C » Mon Jan 21, 2019 8:02 am
J.C Mon Jan 21, 2019 8:02 am
Hi Rick,
This configuration looks ok. Is your computer still less responsive with this setup?
CPU – i7 8700k 4.8Ghz + 64GB RAM, GPU – 2xGTX 980 Ti, 2xRTX 2080
System – OS X 10.12.6, Windows 10, Octane 4/2018, Blender Plugin 16.x.x and 17.x
J.C
Postby protovu » Mon Jan 21, 2019 3:51 pm
protovu Mon Jan 21, 2019 3:51 pm
It seems better, but even though I have this setup, typing this message with a Render preview going is really slow.
I think I need to tell my Nvidia software to have Google run through the 970.
Also, the file I was having the most trouble with uses a few particle emitters. But it seems happier now.
protovu
Postby J.C » Mon Jan 21, 2019 4:13 pm
J.C Mon Jan 21, 2019 4:13 pm
Does it happen the same when you render in Standalone?
J.C
Postby protovu » Mon Jan 21, 2019 5:02 pm
protovu Mon Jan 21, 2019 5:02 pm
I have never used the StandAlone.
What am I missing?
protovu
Postby J.C » Mon Jan 21, 2019 5:24 pm
J.C Mon Jan 21, 2019 5:24 pm
Just test it and observe if the system lags too while rendering in Standalone.
J.C
Postby protovu » Mon Jan 21, 2019 5:33 pm
protovu Mon Jan 21, 2019 5:33 pm
Will give it a go. A bit later, though.
Again,
Thanks for your help, JC.
protovu
Postby protovu » Mon Jan 21, 2019 10:14 pm
protovu Mon Jan 21, 2019 10:14 pm
Hi JC,
Can't get to the Standalone now as I am working on a deadline.
In doing so, getting booted off the Render Server over and over during Render Preview when editing.
Sequence:
edits with Preview
Lose Preview
Z key
restart OctaneRender Server
Z key
Shift+Z Key..
Somewhere behind the Blender interface, if I view my desktop, I can usually find the "Error binding socket......5131..." message.
Big hassle.
Any help? Much needed, thanks.
Rick
protovu
Postby J.C » Tue Jan 22, 2019 12:00 am
J.C Tue Jan 22, 2019 12:00 am
I've never had such error.
Check this out. Maybe this helps:
viewtopic.php?f=32&t=38562
J.C
Postby protovu » Tue Jan 22, 2019 12:39 am
protovu Tue Jan 22, 2019 12:39 am
Hi JC,
Blender is not crashing.
The server is dropping the connection, mainly during edits to a model or shader.
The error message is basically hidden unless I minimize Blender.
I don't think anything else is sharing the port.
I do have Octaner Render for Carrara, but it is not running when this happens.
protovu
Postby J.C » Tue Jan 22, 2019 1:21 am
J.C Tue Jan 22, 2019 1:21 am
Did you update your GPUs and motherboard drivers?
Can you share the scene for a test?
J.C
PreviousNext
Return to Blender
Mon Aug 19, 2019 11:01 pm [ UTC ]
