OctaneRender 4 for Revit [OBSOLETE]
Forums: OctaneRender 4 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Postby face_off » Wed Nov 21, 2018 1:04 am
face_off Wed Nov 21, 2018 1:04 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit - TEST and STABLE releases.
IMPORTANT: If you get an "Exception starting render : System.MissingMethodException..." error when opening the Viewport with Revit 2018, install the Revit 2018.1 (or later) update.
Revit Version
This version runs on Revit 2017, 2018.1 and 2019 on Windows Vista, Windows 7, Windows 8 and Windows 10, 64 bit.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
- If relevant - supply the Journal file for the Revit session where the support issue occurred. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Revit/?page_id=536
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Download Links
Current STABLE build (Octane 4.01.1)
Previous STABLE build (Octane 4.01.1)
Release History
4.02.1.60 (12-Apr-2019)
- Resolved issues with materials not rendering correctly or being editable introduced in 4.02.1.58
4.02.1.58 (19-Feb-2019)
- Compiled with Octane 4.02.1
4.01.1.57 (12-Dec-2018)
- Compiled with Octane 4.01.1
- Fixed issue where opening the plugin whilst viewing a 3d view would cause the materials to be reset to their default
4.00.0.57 (01-Dec-2018)
- Fixed bug where the Denoise Beauty pass could not be selected from the render passes combo box on the Viewport toolbar
- When you Viewport Navigation mode, the camera position and target pins can now be edited
4.00.0.56 (22-Nov-2018)
- Compiled with Octane 4.00. (To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.)
- Changed Devices tab to use the Octane API panel
- Added Denoiser options in the Imager settings
- Added Denoised Beauty pass to the Select Render Pass combobox on the Viewport toolbar
- Added Kernel AI Light options
- Added RenderPasses Denoiser passes
Re: OctaneRender 4 for Revit [TEST and STABLE]
Postby Seekerfinder » Fri Nov 23, 2018 3:24 pm
Seekerfinder Fri Nov 23, 2018 3:24 pm
Awesome, thanks Paul!
Seekerfinder
Postby Seekerfinder » Sat Nov 24, 2018 2:33 pm
Seekerfinder Sat Nov 24, 2018 2:33 pm
Hello Paul,
We get this error upon trying to open a render viewport.
Revit 2017.
Seeker
Seekerfinder
Postby face_off » Mon Nov 26, 2018 5:36 am
face_off Mon Nov 26, 2018 5:36 am
Revit 2017.
Hi Seeker, can you pls tell me the last version of the plugin that you had installed which worked on Revit 2017?
Postby Seekerfinder » Mon Nov 26, 2018 10:17 am
Seekerfinder Mon Nov 26, 2018 10:17 am
face_off wrote:Hi Seeker, can you pls tell me the last version of the plugin that you had installed which worked on Revit 2017?
Pretty sure it was 3.08.2.53.
Seekerfinder
Postby Seekerfinder » Wed Nov 28, 2018 9:50 am
Seekerfinder Wed Nov 28, 2018 9:50 am
Paul,
Thanks for the PM and the test build. It seems the error was on my part... Looks like I inadvertently installed the 2018 build in the 2017 folder (?!)
Apologies for wasting your time over there...!
Best,
Seeker
Seekerfinder
Postby face_off » Sat Dec 01, 2018 12:41 pm
face_off Sat Dec 01, 2018 12:41 pm
I have updated the STABLE installers at the top of this thread with:
4.00.0.57
Postby Seekerfinder » Sat Dec 01, 2018 7:53 pm
Seekerfinder Sat Dec 01, 2018 7:53 pm
face_off wrote:- When you Viewport Navigation mode, the camera position and target pins can now be edited
Awesome! Thanks Paul
Seekerfinder
Postby face_off » Wed Dec 12, 2018 12:45 am
face_off Wed Dec 12, 2018 12:45 am
I have updated the STABLE build at the top of this thread with:
Please note the material reset issue above is a critical issue, so all users on Revit 2018 and 2019 should update to this build. And please let me know if you find any issues.
Postby face_off » Mon Feb 18, 2019 11:49 pm
face_off Mon Feb 18, 2019 11:49 pm
4.02.1.58
Please note this version does not contain the proposed linked file changes discussed at https://render.otoy.com/forum/viewtopic.php?f=61&t=69739&start=10
Next
Return to Autodesk Revit
Users browsing this forum: No registered users and 15 guests
Thu Apr 25, 2024 12:24 pm [ UTC ]
